Front window Washer fluid thing?
Hey i have a 97 gsr and im kinda confused as weather i have front washer fluid, because when i look at the **** it does show that it should but when i look on the front of my car i dont really see the nozzles where it woudl spray out anyway i was wondering anyone know what to do if it doenst work my back ones work though..
the nozzle is hidden under the hood, and as far as the container holding the fluid for the wipers, the front and rear share the same container. if your asking how to use it, just pull back on the wiper handle for a few secs, the lines might be empty.
thats the weird part my rear one works the water works the front doesnt, ii went outside to check and i cant see it but ill pop the hood tommorrow anyway i think my front ones are broken anyone know some trouble shooing or a way to fix it. thanks
make shure the motor is working. When you pull the window wiper lever, you should hear a motor buzzing. If you dont, check the fuse; if that is good, then your washer spraying motor is shot.
Is the resovior full?
The sprayers may also be clogged, pull them out and blow air threw them, and take a tac and poke bigger hole in the sprayer for fluid to shoot out.
GL :
GL :
i dont know i just never realized they dont work so this was a wake up call when my windshield was dirty .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cloudx71 »</TD></TR><TR><TD CLASS="quote">oh yeah antoehr question front motor and back are they the same? and that would lead for antoher question are hte fuses the same. </TD></TR></TABLE>
Oh yah, i forgot. It must be clogged lines. Take them out and take air compressor hose to blast air through lines. Also take a tac and stick in old sprayer holes to clean out debree
TooManyTickets
30
Jul 16, 2007 09:45 PM
