NSX brakes on integra?
Old Jan 26, 2002 | 12:34 PM
Kakkoii Integra's Avatar
New User
Default NSX brakes on integra?
i'm just dreaming here, but someday i would like to have NSX brakes on my DA. how easy/hard is this? anyone done it? what about the rears, too?
thanks!
jeff
Old Jan 26, 2002 | 12:37 PM
madchiller's Avatar
Premium Member
25 Year Member
Default Re: NSX brakes on integra? (frostwhite92)
it can def be done, if you havent tried to search try that i know this topic has been discussed.
Old Jan 26, 2002 | 12:38 PM
rodimus's Avatar
this has already been done.
some guy from team kosoku (now art n motion)
named nathan pagtama did it on his blue integra..
i believe it was on an import tuner mag issue that
was atleast 2 years ago...his car was pretty much
all show but he did it (the nsx brake conversion)
he had a 94 integ though....
Old Jan 26, 2002 | 12:40 PM
BoroDB8's Avatar
From: Waipahu, HI and Irvine, CA, best of both worlds, USA
Just get a bolt on big brake upgrade. Don't get the aem, its a waste of money (it uses your stock 1 piston caliper). I got the ryan fastbrakes kit. It includes 11" slotted brembo rotors, 4 piston calipers, wilwood pads, and stainless steel wraped teflon brake lines along with anodized mounts for the new calipers.
~jOEL
Old Jan 26, 2002 | 07:40 PM
New User
Default Re: NSX brakes on integra? (Titus333)
that's <U>B</U>rian that runs fastbrakes. yeah, that setup is very cool. but my current fantasy is NSX brakes... any info would be great!
thanks again,
jeff
Old Jan 27, 2002 | 06:50 PM
Rtzx9r's Avatar
GDD 1%
You'd also need a 5-lug conversion correct?
Old Jan 27, 2002 | 07:53 PM
Erik_Pb_Foot's Avatar
New User
Default Re: NSX brakes on integra? (Rtzx9r)
Are ITR calipers much better than the LS calipers?
Old Jan 27, 2002 | 08:55 PM
Phoenix_ITR's Avatar
you'd probably be able to get away with just using the calipers and not the rotors but, then again, i'm not sure how big the difference in rotor thickness is.
Old Jan 27, 2002 | 09:55 PM
Stock R's Avatar
Default Re: NSX brakes on integra? (delinquent)
i believe reading up on this somewhere.
the setup can be put on a teg, but u'r gonna need bigger wheels because the brake setup won't fit because it's too big.
the type r caliper is bigger/better than the ls brakes.. (there's a reason they're on the type R)
if u'r gonna dish out the money to get nsx brakes (not cheap) u might as well get a big brake conversion from somewhere else. the spoons fit really nice and snug with the stock itr rims.
Old Nov 29, 2008 | 07:38 AM
fc3srx729's Avatar
Big up's for the old crew Team Kosoku...!
DBada FM
Sep 4, 2010 04:11 PM
s2kb0i
Honda S2000
24
Jul 1, 2006 10:47 AM
idriveadelsol7
Jul 30, 2005 09:36 AM
94CIV
16
Apr 7, 2005 09:53 AM
93SSPHatch
May 15, 2002 05:17 AM
