What to do before roadtrip?
Old Jan 26, 2002 | 12:22 PM
LSpeed's Avatar
Default What to do before roadtrip?
OK I am going to be driving from SLC to LA and I was just wondering what I need to check out to make sure that my car will be ok. I have gone 67k without any problems. I keep up on the maintenence but I just want to check to see if i might be missing anything.
Old Jan 26, 2002 | 12:40 PM
madchiller's Avatar
Premium Member
25 Year Member
Default Re: What to do before roadtrip? (LSpeed)
air pressure, spare tire air pressure, coolant level, oil level
Old Jan 26, 2002 | 12:42 PM
Anthony K's Avatar
New User
Default Re: What to do before roadtrip? ( DoEs AnYoNe KnOw WheRe I CaN GeT SoMe StRObE LiTEZ
Windshield wiper fluid level. Hehe.
Old Jan 26, 2002 | 12:48 PM
2005 TSX's Avatar
Brake pads and Brake fluid (see if they are worn)
Oil change (check like mentioned above)
Air filter
Is your car manual or automatic? Check tranny fluid
Battery water level
Belts (check for cracks)
Spark plugs/wires
Radiator fluid/overflow container
Tire wear/tread
Old Jan 26, 2002 | 01:01 PM
Phoenix_ITR's Avatar
if you're going on a fairly lengthy road trip, you might want to look into a car bra as well.
Old Jan 26, 2002 | 04:10 PM
Wormaker's Avatar
New User
Default Re: What to do before roadtrip? (delinquent)
Don't forgets some snacks and drinks, and some cd's tooo!
Old Jan 26, 2002 | 04:21 PM
GSRaCeRbOI's Avatar
2001 Integra GSR has a good list..
check all your fluids..
if i was going on an extended trip.. i'd go over everything covered on the 30K (major) maintenance if you havent already just to ensure the car is running in top condition... on a long trip you DONT want to be breaking down..
check your spare tires air pressure.. and bring your cell phone in case anything happens..
Old Jan 26, 2002 | 04:31 PM
type r 01-1063's Avatar
don't forget to make sure you have a properly inflated spare tire/jack kit in the trunk.
sometimes people remove it for weight reduction and forget to put it back when they will actually need it
Old Jan 26, 2002 | 05:03 PM
2005 TSX's Avatar
Just a side note...
I used to own a 1975 and 73 VW Bug. My car tended to break down. So I made myself a box with essential equipment in case I did break down. It included...
Screw drivers (Phillips and Flat Head)
1 Quart of oil (just in case my engine was consuming more than usual)
Jumper cables (a must)
Spare rags
Fuses
Flashlight
Spare Alternator Belt
13mm socket and bar (for changing tires)
Calling card
VW Idiots book (old VW repair manual)
Old Jan 26, 2002 | 11:44 PM
Grandprix's Avatar
Default Re: What to do before roadtrip? (2001 Integra GSR)
gas
cash
bitches
Old Jan 27, 2002 | 08:43 AM
sutrusu's Avatar
Default Re: What to do before roadtrip? (Grandprix)
gas
cash
bitches
mmm all i need in life
Old Jan 27, 2002 | 01:39 PM
LSpeed's Avatar
Default Re: What to do before roadtrip? (sutrusu)
Thanx for the imput guys, My tires are are almost to the replacement indicater but I am pretty sure that they will last a few thousand more miles. I just don't want to get new tires and wear them out in a week. How hard is long distance driving on your tires anyways? I would think that the heat from driving for a long time might wear them out faster but on the other side driving in a straight line without much stop and go would not wear them that much. Anyone know? Oh and about the gas, cash, and bitches, I will be stopping and spending a night in Vegas both ways so you never know, I may just get lucky .
Old Jan 27, 2002 | 01:46 PM
jinxproof99's Avatar
New User
buy alot of beer and drink it.
Old Jan 27, 2002 | 01:47 PM
Dirt's Avatar
I'll be getting new tires (Sumitomo HTRZII) before I leave for Tampa in March..... 3,500+ miles on new tires. Better to have peace of mind.
Old Jan 27, 2002 | 01:54 PM
threatcon13's Avatar
New User
Default Re: What to do before roadtrip? (MmmVTEC)
when are u leavin ? can i hitch a ride?
Old Feb 2, 2002 | 04:35 PM
Johnny Gasparini's Avatar
I didn't ask for a dime.
Default Re: What to do before roadtrip? (DontBother)
Don't forget to check your blinker fluid and as a rule of thumb, recalibrate your flux capacitor.
Old Feb 2, 2002 | 05:37 PM
Astro's Avatar
Ah... I thought the same thing when I did my '97 Road Trip. I had 46,000 miles on the factory tires and they had a lot of tread on them. I didn't think anything of it until the second day of driving, but the one tire was losing about 5-6psi every 6 hours of driving. The result was after 4 hours the car would want to start pulling off to one side. This made driving difficult.
Regarding wheels / rims / tires - make SURE the tires are properly balanced!! I can't stress that enough. I'm one of those people that hates having the wheel and/or seat shake all over the place and the car started doing that on the 3rd day of driving.
I should mention the car used was a '94 Ford Escort (yuck).
Drive the car on the freeway at your average speed and hold it for a couple minutes and determine if you can handle any shaking or vibrating.
As for servicing, I took the car to the dealer 2 weeks before the trip and had them do a 30,000 service (the car had probably 44-45,000+ miles and had the 30k done at 30k). Sadly, the Ford dealer I went to didn't know how to balance tires on their own product (which makes me worried).
I also managed to rear-end someone (in the high speed lane too!) a week before the trip. That shook me up pretty bad (no one was hurt and there was very little damage). I think that also put a flat spot on the front tires which didn't help matters.
I travelled pretty light in the tools department. Basically I just had a pocket knife and a tire gauge and that was about it. The car made it to two service stations to deal with the tire problems.
We didn't have access to a cell phone and I still don't have one. I can see them being pretty handy (or at least a calling card). We did have a CB in the car and that provided for some entertainment when we got tired of the CDs.
Pics from the trip
Another fun thing we did was eliminate all stops to fast food joints and stop only at mom and pop places, diners, or truck stops. That made the trip really cool. Try it out - you can always eat fast food when you get home!
Old Feb 3, 2002 | 02:42 AM
New User
Default Re: What to do before roadtrip? (JSM)
second foolish coment Ive heard from you
miguey310
13
Jul 19, 2009 04:06 PM
.M.
Mar 25, 2004 08:16 AM
uNF$@#!
Mar 1, 2003 08:10 PM
jokerstud
Dec 22, 2002 08:27 PM
Steppin Razor
Sep 21, 2001 02:42 PM
