Homecoming: My 3rd EF...first CRX...idle problem?
Old Mar 28, 2005 | 06:44 PM
skud_dusty's Avatar
Default Homecoming: My 3rd EF...first CRX...idle problem?
First off, I'm Mike...and here's my 3rd EF:
90 Civic Si: d16z6, i/h/e
91 Civic Dx: cut springs/muffler... hated
91 CRX Si: Only has a short ram intake...but it's got an idle problem
The car has 98k on it, and is my first CRX
When the car is warm, and I come to a stop, the idle will drop down to ~400 rpm or so, then pop back up to ~800...
Any ideas? I couldn't find a vacuum leak, but I need to take a closer look when it's not rainy...
Old Mar 28, 2005 | 07:07 PM
tealjdmcrx's Avatar
Default Re: Homecoming: My 3rd EF...first CRX...idle problem? (skud_dusty)
IAC valve may have taken a dump but check tb for carbon build up, timing , or maybe even the coolant level.
Old Mar 28, 2005 | 07:26 PM
ppfalcon's Avatar
http://www.ef-honda.com/ben/Badidle.php
this link should help you out..
Old Mar 28, 2005 | 07:28 PM
kulangot's Avatar
Default Re: Homecoming: My 3rd EF...first CRX...idle problem? (2ndgenrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2ndgenrx &raquo;</TD></TR><TR><TD CLASS="quote">IAC valve may have taken a dump but check tb for carbon build up, timing , or maybe even the coolant level. </TD></TR></TABLE>
btw nice crx, good luck...
Old Mar 28, 2005 | 07:33 PM
skud_dusty's Avatar
Default Re: Homecoming: My 3rd EF...first CRX...idle problem? (sirq2u)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sirq2u &raquo;</TD></TR><TR><TD CLASS="quote"> btw nice crx, good luck...</TD></TR></TABLE>
The front end it smacked up a little, but thanks for the compliment
Don't worry, you won't see this car getting riced out
Old Mar 28, 2005 | 07:48 PM
coot_er's Avatar
that link needs to be added to the FAQ
Old Mar 28, 2005 | 08:08 PM
mr_valentino20032000's Avatar
Default Re: Homecoming: My 3rd EF...first CRX...idle problem? (coot_er)
yeah my ZC has a horrible idle problem. Now i have a starting point to fix it this weekend
TurboLex's Avatar
check your throttle cable. it might be too tight. thats what my problem was. actually thats what my problem still is. it's creating a very very slight vacuum leak. it's worth a shot. it only takes like 2 minutes to tighten and loosen it anyway. good luck.
Old Mar 29, 2005 | 05:52 AM
skud_dusty's Avatar
Default Re: Homecoming: My 3rd EF...first CRX...idle problem? (TurboLex)
Thanks alot for the information guys!
Is there any idle control screw, or is it all electronically controlled?
I read the thread on EF-Honda, and it just talked about cleaning out everything that's associated with the idle, not necessarily adjustments...
Old Mar 29, 2005 | 01:15 PM
CRXVTEC69's Avatar
TPS bro. I dont know how many times I have to say it but its true.....replace the TPS. EBay for like $9.00 hahaha
Old Mar 29, 2005 | 01:19 PM
LShatchie's Avatar
Default Re: Homecoming: My 3rd EF...first CRX...idle problem? (CRXVTEC69)
yeah its possible it is the tps... if ur not getting a code then usually its just that u need to adjust it, not replace it.
Old Mar 29, 2005 | 05:20 PM
SwissChEz82's Avatar
Default Re: Homecoming: My 3rd EF...first CRX...idle problem? (civichatch6989)
It doesn't sound like the IACV, that is usually at a higher RPM, if it has a an idle adjuster screw I would start there. If not I wouldn't know haven't dealt with the z6 yet.
Old Mar 29, 2005 | 07:05 PM
skud_dusty's Avatar
Default Re: Homecoming: My 3rd EF...first CRX...idle problem? (SwissChEz82)
I've also noticed that the car doesn't really pull hard up past 5k or so...
I haven't driven an EF w/ a stock A6 before, does this point more towards the TPS?
Old Mar 30, 2005 | 10:38 AM
Bull_head360's Avatar
crx's suck!! just playin, does the idle go up and down and up and down and up and down? or does it just go down to 400 then up to 800 and hold? u remember my problem, right? and is it gradual change in rpm or is it a sharp change?
Old Mar 30, 2005 | 10:41 AM
lunchboxEF91's Avatar
nice crx....and good luck on the idle situation
Old Mar 30, 2005 | 11:46 AM
Rex_Ryder's Avatar
let me know if you get it fixed. i'm having the same problem with my ZC and i haven't been able to find the problem.
Old Mar 30, 2005 | 08:14 PM
skud_dusty's Avatar
Default Re: Homecoming: My 3rd EF...first CRX...idle problem? (Nu_At_It_CRX)
It just drops down to ~400 and stays there. Every now and then it'll pop up...but it usually just stays around 4 or 5 hundred..
Old Apr 3, 2005 | 12:49 PM
RC_SKUBY's Avatar
you think your cars got a idling problam you should hear parkers any luck fixing the beast yet?
Old Apr 3, 2005 | 02:47 PM
skud_dusty's Avatar
Default Re: Homecoming: My 3rd EF...first CRX...idle problem? (skuby_do)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skuby_do &raquo;</TD></TR><TR><TD CLASS="quote">you think your cars got a idling problam you should hear parkers any luck fixing the beast yet?</TD></TR></TABLE>
Haven't had time to **** with it. Hopefully this week in class I'll be able to take care of it.
That's the least of my problems though. Time to look into rust repair
tylertocker
Apr 20, 2008 01:06 PM
crazeerican
Feb 26, 2008 01:50 PM
tico
Jul 18, 2006 04:44 PM
k7q
Dec 28, 2005 07:43 PM
Luke J
Apr 17, 2003 04:40 AM
