quick simple question CRX cluster VSS --help
Old Mar 28, 2005 | 06:16 PM
jhmcrx's Avatar
Default quick simple question CRX cluster VSS --help
ok i have an 88 crx i had a vss problem it just so happens that i swap my dash for a 91 dash, and changed my cluster but i still have the vss problem! i thought that the sensor is in the cluster isnt it??
Old Mar 28, 2005 | 06:20 PM
kulangot's Avatar
Default Re: quick simple question CRX cluster VSS --help (jhmcrx)
check your vss cable...
Old Mar 28, 2005 | 06:23 PM
jhmcrx's Avatar
Default Re: quick simple question CRX cluster VSS --help (sirq2u)
hmm didnt think of that, but yes it plugged in correctly on both ends... how can i tell if it defective?
Old Mar 28, 2005 | 06:36 PM
WhiteDSM520's Avatar
Its probably broken in the middle. Try pulling it completely out.
Old Mar 28, 2005 | 06:37 PM
kulangot's Avatar
take it out and spin it on one end and see if the other end moves.....
Old Mar 28, 2005 | 06:41 PM
jhmcrx's Avatar
oh it does spin it only thows a code when i downshift to a low gear at high rpms or if i stay in gear going downhill etc.. but regardless it always spins but it thows a code
Old Aug 1, 2005 | 09:07 AM
wrXtian's Avatar
i have the same problem.. it takes a while for the cel to come on, but my speedometer works that's the strange thing..
Old Aug 1, 2005 | 10:51 AM
wrXtian's Avatar
Default Re: quick simple question CRX cluster VSS --help (D16A6_HF)
it wouldn't be a faulty cluster if the gauge still works right? possibly wiring?
Old Aug 6, 2005 | 11:11 PM
LudeJdm's Avatar
i have the same problem....when you first start your car...the cel doesnt come on but after a while on high rpms.....or downhill.....or stay in gear too long the cel pops on....anyone know if they are still hitting vtec??? or anyone know how to fix this???
GhostBoy99
Apr 28, 2019 01:17 PM
Bill Andrews
Feb 22, 2019 12:18 PM
ram0869
Sep 5, 2009 09:11 PM
h22_crx
Jul 16, 2008 07:07 PM
ma_rio44
11
Jul 15, 2007 09:24 AM
