gas lens= big thumbsup
Old Mar 28, 2005 | 06:15 PM
CRFAB04's Avatar
Default gas lens= big thumbsup
i have just started recently using the gas lens and it is the best. i can crank up the heat now and still get the good color. tell me what u guys think.
Old Mar 28, 2005 | 06:18 PM
ChainbreakR's Avatar
Default Re: gas lens= big thumbsup (CRFAB04)
Looks good man... the weld you laid in the second pic of the pipe to the flange looks excellent. The collector looks pretty darn good too!
Old Mar 28, 2005 | 06:19 PM
azfab1031's Avatar
looking really good. Yeah gas lenses really do the trick !!
Old Mar 28, 2005 | 06:34 PM
jon volk's Avatar
Default Re: gas lens= big thumbsup (azfab1031)
What exactly DOES a gas lens do? Everyone seems to recommend them and the results look pretty damn good.
Old Mar 28, 2005 | 06:53 PM
CRFAB04's Avatar
Default Re: gas lens= big thumbsup (k20 jon)
i will try to explain it briefly. engloid will prolly tell u better. it actually has a screen inside the nozzle itself that dispurses the argon over a wider area of the surface that is being welded. that is my summary of how it works. could be wrong though.
Old Mar 28, 2005 | 07:18 PM
Keyhole's Avatar
Where can you purchase a gas lens?
Old Mar 28, 2005 | 07:41 PM
Engloid's Avatar
OG Fabricator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRFAB04 &raquo;</TD></TR><TR><TD CLASS="quote">i will try to explain it briefly. engloid will prolly tell u better. it actually has a screen inside the nozzle itself that dispurses the argon over a wider area of the surface that is being welded. that is my summary of how it works. could be wrong though.</TD></TR></TABLE>
Not much more to say...it just helps cover the weld and heat affected zone better.
Welds look pretty good...if you walk the cup, the butt welds would look much better.
Old Mar 28, 2005 | 07:42 PM
LostCRX's Avatar
what is the thickness of the metal and what amperage were you at if you don't mind me asking? how fast were you going? that are some nice beads.
Old Mar 28, 2005 | 08:04 PM
01geeser's Avatar
New User
Default Re: gas lens= big thumbsup (Keyhole)
here http://store.aglevtech.net/tigtoandac1.html
Old Mar 28, 2005 | 08:11 PM
CRFAB04's Avatar
Default Re: gas lens= big thumbsup (01geeser)
that is sch 40 pipe. it has about a .125 wall thickness.
Old Mar 28, 2005 | 08:39 PM
ImSIR2u's Avatar
Default Re: gas lens= big thumbsup (Engloid)
What do you mean by walk the cup??
Old Mar 28, 2005 | 09:01 PM
HotRodTeg's Avatar
Default Re: gas lens= big thumbsup (ImSIR2u)
Nice welds. how do you get that nice gold color? Is it just because you are welding stainless? Or can you get that color on any meterial?
Old Mar 28, 2005 | 09:18 PM
Engloid's Avatar
OG Fabricator
it's a method of rolling the cup back and forth in a zig zag pattern while making a weld. When done properly, it really helps stability and consistency...as well as speed. When you know how to do it, it's much easier to do than a freehand weld.
Old Mar 29, 2005 | 03:07 AM
LostCRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRFAB04 &raquo;</TD></TR><TR><TD CLASS="quote">that is sch 40 pipe. it has about a .125 wall thickness. </TD></TR></TABLE>
thanks, and what amperage were you at?
Old Mar 29, 2005 | 04:10 AM
CRFAB04's Avatar
Default Re: gas lens= big thumbsup (LostCRX)
that was done at around 90 or so. good penetration. the manifold that i did before that one, i walked the cup. it did look much better.
Old Mar 29, 2005 | 07:48 AM
Mr.JaCkeL26's Avatar
what size tugsten did you use? 3/32 or 1/8th inch?
Old Mar 29, 2005 | 08:41 AM
ineedhelp's Avatar
Default Re: gas lens= big thumbsup (StOoTs26)
im still new to welding and im about to do my first manifold. i dont have scrap metal to practice fillet welds so...
whats was the procedure you took on welding the pipe to the flange? amperage, filler size, etc.
thanks.
Old Mar 29, 2005 | 06:26 PM
AutoLab's Avatar
Default Re: gas lens= big thumbsup (ineedhelp)
how many passes are your butt welds? what size filler rod are you using? welds look really good!
Old Mar 29, 2005 | 07:29 PM
CRFAB04's Avatar
Default Re: gas lens= big thumbsup (AutoLab)
i'm using 3/32 tungsten. i always run 2 passes on each joint. 3/32 filler also.
Old Mar 29, 2005 | 07:34 PM
lets see the manifold now...
AutoLab's Avatar
any filler on the root pass? welds look really good, Ive been meaning to pick up a gas lense. good post
Old Mar 30, 2005 | 04:23 AM
CRFAB04's Avatar
i do use filler on the first pass. 3/32 on both passes. i'll post pics of the manifold that i am about to ship out for a customer. wait until firday or so, i have to finish his whole setup first. i laid down some pretty fat welds kind of like lovefab.
Old Mar 30, 2005 | 07:11 AM
92SleepyHB's Avatar
Damn Ross lookin Clean
Old Mar 30, 2005 | 09:04 AM
CRFAB04's Avatar
Default Re: gas lens= big thumbsup (92SleepyHB)
hey B-rad. i'll be up there tomorrow to show u my last manifold.
Old Mar 30, 2005 | 09:40 AM
Engloid's Avatar
OG Fabricator
Got any pics of the inside?
