anyone using omnipower drag combo coilovers?
Old Mar 28, 2005 | 04:41 PM
redboost10's Avatar
Default anyone using omnipower drag combo coilovers?
i got the drag combo kit, 12k front/18k rear. im trapping 120 mph but my et is 12.0?'s. i had the front the lowest it could go with the slicks mounted on, and i had the rear the highest i could get them. my car with me weighs about 2350. im spinning big time but my 60' is 1.8 sec. using mh 24.5/8/13 with weld racelites 13/8. should i lower the rear of the car? i know 120mph is good for mid 11's.
any help is appreaciated. thank you.
Old Mar 28, 2005 | 05:20 PM
buck02's Avatar
Default Re: anyone using omnipower drag combo coilovers? (tgh99si)
get some limits straps from me it will hole the face of the tire on the pavment
Old Mar 28, 2005 | 05:26 PM
redboost10's Avatar
Default Re: anyone using omnipower drag combo coilovers? (buck02)
i was thinking of going that route, with limits straps and/or traction bars. but first i wanted to see why im having such bad traction problems for only 14 psi. i heat the heck out of the slicks.
does anyone else use this suspension setup?
Old Mar 28, 2005 | 06:05 PM
VTECJUN's Avatar
I just got mine today. They are the same 18k rear and 12k fronts. It will be a week or so before I can get the car tuned so I can let you know then. What tire pressure are you running?
Old Mar 28, 2005 | 06:07 PM
redboost10's Avatar
Default Re: anyone using omnipower drag combo coilovers? (VTECJUN)
i was running 10 lbs to start with and i was spinning 1-3 gears, then i lowered it to 8.5 and no change, so i tried 7 lbs and im still spinning.
Old Mar 28, 2005 | 06:09 PM
redboost10's Avatar
with 7lbs. it sure took off very quickly. but still spun very bad in 2-3 gears. im also going to balance the corner weight of the car. hopefully this will help.
Old Mar 28, 2005 | 06:11 PM
VTECJUN's Avatar
Another thing...how old are the slicks? I had a set that layed around for a while and they dried out. I tried to use them and I had the same problem.
Old Mar 28, 2005 | 06:13 PM
redboost10's Avatar
i bought them brand new last year and only put two runs on them last season towards the end of the season then got kicked out for no roll bar, now with the new lighter car, they only have 3 runs, so 5 runs all together. they were in my closet all winter, not out in the garage or outside. so at room temp all winter long, i figured that would be the best for them.
Old Mar 28, 2005 | 06:35 PM
redboost10's Avatar
another question, is 120 mph mid 11's?
Old Mar 28, 2005 | 06:52 PM
HYBRID_H@TCH's Avatar
hows your alignment?
other than that try to run a little less tire pressure..once it hooks you should lose a few mph but gain the et your looking for..
Old Mar 28, 2005 | 07:06 PM
redboost10's Avatar
Default Re: anyone using omnipower drag combo coilovers? (99Hybrid_Hatch)
i got an alignment right after i installed the suspension. after i balance the weight at the corners, ill mess with lower tire pressure again. what about the ride height of the car, like should the rear be higher or lower than the front with this suspension? should the front be as low as possible with the slicks mounted on the car?
oh yeah i also have a quaife, which makes me more pissed about this.
Old Mar 28, 2005 | 07:36 PM
buck02's Avatar
i use 6.5 psi
on my 25inch slick
Old Mar 28, 2005 | 07:40 PM
redboost10's Avatar
i guess ill have to lower the pressure more
Old Mar 28, 2005 | 07:46 PM
I run in the 5's for tire pressure..
Old Mar 28, 2005 | 07:52 PM
redboost10's Avatar
wow, hopefully that will help out. as for the height of the rear and front, what should i do with the suspension?
Old Mar 28, 2005 | 07:54 PM
redboost10's Avatar
the thing that gets me thinking and concerned is last summer, i had a 99 si 2600 lbs. same exact set up and i ran a 11.8 at 120 mph and i was spinning pretty bad also. i figured this lighter car would be faster.
Old Mar 28, 2005 | 09:14 PM
redboost10's Avatar
will someone point me in the right direction on how to adjust the suspension itself, heightwise? thank you. ive heard both ways, rear end raised, rear end low as it could go. is their opinions on this or facts? thank you very much.
Old Mar 28, 2005 | 10:34 PM
DIRep972's Avatar
Smarter than you
14psi might be too much power for 1st gear. 7psi should be good in the tires. What launch rpm are you using?
As for the omnipower drag coilover, check out the Rage car I believe 10.0 @ 136 so they musta worked decent!
Old Mar 28, 2005 | 10:48 PM
redboost10's Avatar
Default Re: anyone using omnipower drag combo coilovers? (DIRep972)
oh i know the suspension is a great setup, just still messing with the tire pressure and adjustment of it. i am running 14 psi of boost. and 7 psi of air in the tires. i am launching at 7k-7.5k rpm and it takes off the line good, 1.8 60' ft times all the time. but once i shift into second and third its just spinning. i just mainly wasnt sure about the height of the car and how it should be with the adjustable suspension
i agree 14 psi is too much for 1st gear. but just wondering what i could do to work with what i got.
Old Mar 29, 2005 | 07:36 AM
BolivianFuego's Avatar
Yea try lower tire pressure, its all personal preference on what tire pressure works for what. Just experiement until you get that desired Time in the 1320.
Old Mar 29, 2005 | 08:55 AM
redboost10's Avatar
Default Re: anyone using omnipower drag combo coilovers? (BolivianFuego)
i definately will, thank you all for the help and advice.
Old Mar 29, 2005 | 09:10 AM
turbo*s2k's Avatar
definetly go a little lower in the tire pressure. I usually run about 6-7 psi, and should probably go a tad lower, but I"m still running stock axles and I'm okay with a little tire spin.
How about stepping up to a 25" slick.
Old Mar 29, 2005 | 09:26 AM
redboost10's Avatar
Default Re: anyone using omnipower drag combo coilovers? (TurboChrgd_Civic)
yeah when its time for some new slicks, ill will get taller ones, i guess. now should i raise the rear of the car or lower the rear of the car, or does it even matter with the stiff suspension?
Old Mar 30, 2005 | 03:03 PM
redboost10's Avatar
can someone help with me with the height adjustment? what seems to work best?
Old Mar 30, 2005 | 03:29 PM
DIRep972's Avatar
Smarter than you
There really is no magic to it. Just lower it as much as possible to keep the CG low but not too low that it rubs the tires. Also, the omni's allow you to set the ride height w/ out compressing the shock so first preload the coilover(instruction how should be included in ur box) and then set the ride height using the collars only.
