oil question
Old Mar 28, 2005 | 03:46 PM
osuperjohno's Avatar
Default oil question
I bought oil by the bottles to do my oil change but haven't done it yet, I haven't opened the bottles in 3 months, does oil expire even though i didn't open the bottles?
Old Mar 28, 2005 | 04:23 PM
BDietrich84's Avatar
Default Re: oil question (osuperjohno)
i really dont think it does, i used to work at a quick lube and we had some stuff on the shelf that was left over from the 80's and we still were told to use it.
Old Mar 28, 2005 | 04:24 PM
Default Re: oil question (BDietrich84)
and i dont think it would expire after only 3 months anyway
Old Mar 29, 2005 | 04:00 AM
JimBlake's Avatar
Once it's open & put in your engine it gets moisture, wear metals, & combustion products. That stuff makes it go bad in 6 or 12 months even if you store the car. That stuff doesn't happen to an unopened bottle of oil.
Old Mar 29, 2005 | 04:01 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BDietrich84 &raquo;</TD></TR><TR><TD CLASS="quote">... we had some stuff on the shelf that was left over from the 80's and we still were told to use it.</TD></TR></TABLE>So that was like API SE or SF?? That's NOT good for today's engines...
Old Mar 29, 2005 | 01:03 PM
Default Re: oil question (JimBlake)
i dont really know. it was havoline 10w40. the stupid hillbilly that managed the place told us to use all of it because he wanted to save money. I "borrowed" some and put it in my old clunker 86 ltd and it seemed to run fine.
Old Mar 29, 2005 | 04:34 PM
goowakjai
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">Once it's open & put in your engine it gets moisture, wear metals, & combustion products. That stuff makes it go bad in 6 or 12 months even if you store the car. That stuff doesn't happen to an unopened bottle of oil.
water seeps thru plastic over time...dont know how long though, but i was always told never to buy brake fluid that comes in plastic bottle
Old Mar 29, 2005 | 04:57 PM
Bror Jace's Avatar
Default Re: oil question (goowakjai)
brake fluid is hygroscopic ... actively absorbs moisture.
The same is not true of motor oil. It will store in its plastic bottles for years. Only when it's several years old would I not use it.
I've seen a car stored for over a year with the same oil in the sump. The oil was finally changed and a sample of the old oil was sent to a lab like this one:
http://www.blackstone-labs.com/
Oil looked fine. Little wear or contamination.
Don't worry about it.
TunerShark
20
Jan 4, 2007 12:00 PM
99fbpem1
Aug 22, 2006 10:33 AM
kornerk12
Jan 6, 2006 09:10 AM
stasi
May 11, 2005 08:16 PM
azian21485
Mar 28, 2005 07:41 AM
