Cold outside = problems shifting
Old Mar 28, 2005 | 03:39 PM
p nut's Avatar
Default Cold outside = problems shifting
It was snowing outside today and while I was driving around, it suddenly felt like someone poured mud into the transmission--my shifter felt very stiff. Then, I backed out of a driveway, and I couldn't get it out of reverse. I finally had to just yank it out of there. And this was while the car was warmed up already. I read a few posts on here with people who had similar problems. They suggested changing the oil (which I did last Saturday, with Honda MTF), and that was pretty much it. Any other suggestions?
Old Mar 28, 2005 | 03:49 PM
Stein's Avatar
Default Re: Cold outside = problems shifting (P Nut)
Same here, when my tranny is cold it's pretty stiff, even with new MTF.
Old Mar 28, 2005 | 03:51 PM
EuN_TeK's Avatar
Do you have an aftermarket short shifter? I heard that might be the cause of the problem. Had the same problem and posted and remember people telling me the change back to stock and the problem should be fixed, but I haven't driven it all winter so...
Old Mar 28, 2005 | 03:57 PM
Mythias's Avatar
Default Re: Cold outside = problems shifting (Stein)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stein &raquo;</TD></TR><TR><TD CLASS="quote">Same here, when my tranny is cold it's pretty stiff, even with new MTF.</TD></TR></TABLE>
Same here... but what bothers me is that he said he was driving around, and it happened all of a sudden.
Old Mar 29, 2005 | 07:07 AM
p nut's Avatar
Default Re: Cold outside = problems shifting (EuN_TeK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EuN_TeK &raquo;</TD></TR><TR><TD CLASS="quote">Do you have an aftermarket short shifter? I heard that might be the cause of the problem. Had the same problem and posted and remember people telling me the change back to stock and the problem should be fixed, but I haven't driven it all winter so...</TD></TR></TABLE>
Actually, I do have a short-shifter. However, I really don't see how that could be the problem.
Also, I should also clarify that my shifter went into "sloth-mode" when snow actually started accumulating on the ground. I don't know if that has anything to do with it, though...
boostmee
Jun 14, 2007 12:37 PM
EsQueue
Acura TL, RL & ZDX
29
May 20, 2007 11:17 PM
Nicks95GSR
Apr 23, 2007 04:05 PM
C8V6C
Jan 11, 2004 03:49 PM
brian estrada
Sep 26, 2003 12:16 AM
