JDM door visor Need help.
I know installing a door visor is not rocket science. But I just can't seen to figure it out. Did a search found some good info, but none of them show how to install them.
Oh btw it for civic 92-95 hatchback.
these are for an EK... i'm assuming it's the same for EG.
https://honda-tech.com/zerothread?id=632263
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaiba »</TD></TR><TR><TD CLASS="quote">I know installing a door visor is not rocket science. But I just can't seen to figure it out. Did a search found some good info, but none of them show how to install them.
Oh btw it for civic 92-95 hatchback.</TD></TR></TABLE>
The JDM OEM ones for the EG/EH's are a bitch if you don't put it in right the first time. Almost too easy to break the metal clips. Just peel out the inner weather rubbering from the highest point of the window to the lowest point by the top-corner of the mirror. When you're doing the mirror area, don't pull it down any further than a half ince to an ince below that corner.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MASTRCHANN »</TD></TR><TR><TD CLASS="quote">these are for an EK... i'm assuming it's the same for EG.
https://honda-tech.com/zerothread?id=632263</TD></TR></TABLE>
Different. The one's for the 96-00's are much easier. They screw in to pre-drilled holes underneath the weather rubbering. I like this method much better.
myronwong
Jul 17, 2007 03:53 AM
kos99ngel
Mar 17, 2006 06:28 PM
