Dont know what kind of shocks are good?
Im trying to put some new shocks on my Integra 91 LS but i dont know which shocks are good?. I was looking at some tokico shocks already they look pretty good but im still not sure. My car has the coiliver springs already mounted on the OEM shocks and it rides like ****. Guys please give some suggestions...
Look in our sponsor section, they have good deals on just about everything.
And personally, i'd go with the Koni Yellows. And before buying anything, search around and see what people recommend and read their reviews to see which shock will best fit your needs.
Ali
Ali
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG »</TD></TR><TR><TD CLASS="quote">koni yellows & kyb agxs are good</TD></TR></TABLE>
If you're drop is greater than 1.5" I wouldn't recommend AGX's. They're only warrantied for drops up to 1.5" and not meant for high spring rates. I have AGX's, because my drop is only .75"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by timmy8151 »</TD></TR><TR><TD CLASS="quote">
If you're drop is greater than 1.5" I wouldn't recommend AGX's. They're only warrantied for drops up to 1.5" and not meant for high spring rates. I have AGX's, because my drop is only .75"</TD></TR></TABLE>
I agree, also, if you have a 91 Integra, they don't make the rear set of KYB AGXs for 90-93 Integras, so you will have to order the ones for the 94-01 Integra/92-95 Civic. They will bolt right up, although they are a slightly different size. You can then either run 90-93 AGXs in the front, or swap out front drop forks and use 94-01 Integra/92-95 Civic ones.
With a big drop, I would go with Koni Yellows though. But if you do need to save money, the AGXs are only $300 and will do ok for awhile, although you will void the warranty and need new ones eventually.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khg186 »</TD></TR><TR><TD CLASS="quote">Yo when you put the AGX does the still bounce?</TD></TR></TABLE>
I have H&R OE's on my car which have a relatively low spring rate. I don't have any problems with bouncing. To the original poster, you're going to want a shock that has the valving to handle the spring rate you're running.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purplegsr (Exospeed) »</TD></TR><TR><TD CLASS="quote">
With a big drop, I would go with Koni Yellows though. But if you do need to save money, the AGXs are only $300 and will do ok for awhile, although you will void the warranty and need new ones eventually.</TD></TR></TABLE>
i have a 2 in drop on my car with agx with modded top hats and they dont bounce, also my car is a 91 rs with 90-93 front and 88-91 ef rears
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khg186 »</TD></TR><TR><TD CLASS="quote">I couple of my friends told me to go with TOKICO shocks, Are they Good?</TD></TR></TABLE>
illuminas are good too, but from what i've heard the agx'sare better, but koni yellows own all but they are kinda pricey
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khg186 »</TD></TR><TR><TD CLASS="quote">some Tokicos Iluminas (front and rear) for $414.00 on ebay. Is that a good price?</TD></TR></TABLE>
yea thats a good price, i payed alil more for my shocks, but i found em local and did have to wait for shipping so i was okay with spending alil' more money
Im considering getting the KYB AGXs for a 93 DA. Are there any problems that you know of as a result of using rear 94 DC AGXs in this setup? If there are, I may end up going with Omnipower or Skunk 2 coilovers instead. BTW Im not sure If I would get sleeves or simply lowering springs if I used AGXs.
