'Teg ECU w/ New Cam?
Should I go ahead and upgrade to an 89 Teg ECU when I install my new cam? I know the 'Teg ECU has more aggressive fuel maps and such, so I'm thinking it would go good with the more aggressive cam....Yes, no? Any insight on this?
other alternative is chipping, I offer DIY kits which will defiantly improve the performance, such as ZC program, Mugen N1 ZC or others, it only works on the 90-1 ECU only (PM6)
The teg ecu will be fine with your new cam. The increased fuel will be a benefit with the cam. As for the teg ecu eating distributors; I have heard about it but I have not had any experience with it. I used a zc ecu when I had my zc swap.
Are you running an Si engine d16a6? or do you have the ZC...
I ran the JDM DOHC ZC ECU with my Si engine for 1 month, and it ran very aggressive, bit scary, but nice. Not sure if it was safe, cause it had diff fuel maps, not made for the SOHC Si.
My ZC DOHC runs well now with the JDM ECU.
[Modified by dohczc, 8:28 PM 1/28/2002]
My ZC DOHC runs well now with the JDM ECU.[Modified by dohczc, 8:28 PM 1/28/2002]
how can an ecu "eat" a distributor? rule of thumb is use the distributor that matches to the ecu..but of course there are exceptions
im running a fairly high compression (tested about 270psi on all 4 cylinders) d16z6 w/pg7 ecu and it does run it very very rich. i should prolyl go back to my pm6.
I'm actually running the D15B2 w/ MPFI, I/H/E. I'll try to get my hands on a Teg ECU, but I'm still having trouble deciding which cam to go with (Gude, Web, or Crane). I'm thinking Gude though.
from an email GUDE performance has sent to me
Please note the DOHC cams for Honda includes ZC cams!
[b]CAMS SOHC ENGINES.[b] price core total
CAMS SOHC ACCORD 275.00 201.00 476.00
CAMS 12 VALVE CIVIC 275.00 250.00 525.00
CAMS DOHC* ENGINES 594.00 370.00 964.00
*dohc = Neon, Acura, Prelude, miata, mx3, Saturn, Eclipse
CAMS DOHC ENGINES
Ford zx2 zx3 ka24de Nissian 694.00 370.00 1064.00
CAMS SOHC VTEC ENGINE 511.00 448.00 955.00
CAMS DOHC VTEC ENGINE 540.00 650.00 1190.00
PORTED HEAD 4 CLY. 950.00 500.00 1450.00
GSR VTEC & B16A VTEC 950.00 SEND 950.00
PORTED HEAD 6 CLY. 1250.00 SEND 1250.00
HEADER .
ECU UP GRADE. 290.00 CALL 290.00
PORTED INTAKE 120.00 CALL 120.00
TURBO KITS
CAMS DOHC ENGINES
HEADER .
TURBO KITS
kamikaze9i6
14
Jan 4, 2003 01:29 PM
pdiddyparsons
Oct 13, 2002 06:43 PM
