smog????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohc90rex »</TD></TR><TR><TD CLASS="quote">so i jus need a cat? </TD></TR></TABLE>
Yes
Yes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SloA$$ DA »</TD></TR><TR><TD CLASS="quote">EGR valve?</TD></TR></TABLE>
That would be a good idea, but he said he had D16A6... Only automatics and HF's had EGR systems. So he's outta luck there.
sohc90rex:
Have you checked your timing? If it is advanced, that means higher combustion temps. When combustion temps are +2500 degrees NOx forms. Set your timing to the low side of spec.
You can also try running a step colder plug and highest octane gas to cool things down.
You're only failing NOx right? The CO & HC numbers are fine correct?
sohc90rex:
YoungMoneySi
May 25, 2008 06:00 PM
SiRII_Izzy
21
Aug 24, 2004 07:06 PM
