cam gear cover...
how do i get that cover off that is over hte cam gear? any help would be great... i removed 3 skrews and couldnt see anymore... HOW MANY ARE THERE!
Not a bad idea since you have it off. But somtimes you can get by with using the old one. It usally stays in the valve cover anyway when you remove the cover. If not, just slowly pull it off and re-install it. What are you doing in there anyway?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rubixcu7 »</TD></TR><TR><TD CLASS="quote">meh... so i would need a new valve cover gasket?</TD></TR></TABLE>
No.
No.
It would prolly be a good time to check your valve cover gasket anyway. Also, do yourself a valve-clearance adjustment too. I dono... I just always try to find some work to do on the car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">You have to take off the valve cover too. It holds the cam gear cover on.</TD></TR></TABLE>
i cut that little lip off so i just have to remove the 2 bolts and not take off my valve cover if i want to adjust my cam timing
im thikning fuel or ignition... cuz it turns over... but its either gettin no spark or no fuel... gonna check for spark when my girlfriend gets here... WERE GOIN TO DISNEYLAND
alotawatts
10
Dec 20, 2004 09:51 AM
