99si prblm
Old Mar 28, 2005 | 04:19 AM
Grams0wnsyouz99*'s Avatar
Default 99si prblm
when I start gradually excellerating between the ranges of 2000 and 4000 rpm the car will freeze at let say 3200 rpm if i let of the gas it stops but if i just keep steady where i am it will feel like someone is pushing against me and then the car will release and climb rpms normally again, has this happened to anyone? its very hard to explain I tried the best i could, just thought id check to see if its happened to anyone else before i bring it in.
Old Mar 28, 2005 | 04:45 AM
mugen_man's Avatar
Default Re: 99si prblm (GramSilightZ99)
What engine do you have?
Old Mar 28, 2005 | 05:43 AM
ItsFunnerWithGunnar's Avatar
He's got a '99 Civic Si.
Old Mar 28, 2005 | 05:49 AM
mugen_man's Avatar
Default Re: (ItsFunnerWithGunnar)
Well now that we've established that.........WHAT ENGINE DO YOU HAVE? So you have a stock engine, no swaps?
Old Mar 28, 2005 | 05:51 AM
Just didn't know if you didn't catch that...I just assumed he has the stock engine.
Old Mar 28, 2005 | 07:05 AM
LaosGuySi's Avatar
sifu pai mei
well a stock engine on a 99 Si is a b16a2
Old Mar 28, 2005 | 07:11 AM
BauleyCivic's Avatar
Risky Business
Default Re: (LaosGuySi)
Wow, 4 replies that have absolutely nothing to do with his question. Congratulations guys
To the thread starter...I'd say there might be some gunk in your throttle body that is causing your throttle to stick. Try unbolting your throttle body and cleaning it with carb cleaner and see if that does anything.
Old Mar 28, 2005 | 09:06 PM
Default Re: (BauleyCivic)
haha yes i have the stock engine the b16a2...thanks for your help BauleyCivic i will try that
Old Mar 28, 2005 | 10:36 PM
Evo-man@20psi's Avatar
Default Re: (GramSilightZ99)
Also check your thrttle cable
Goobsie
Engine Management and Tuning
Mar 6, 2019 06:40 PM
v8killaz
12
Mar 18, 2011 08:35 AM
Solscud007
Sep 28, 2007 02:19 AM
guts311
12
Aug 27, 2004 04:23 AM
