problem with clutch pedal.....
my car is sitting at a churchs parking lot right now cause my clutch pedal wont come back up when i step on it. i would have to use my foot to pick it up. i cant get my car into gear. it turns on fine and everything. im just wondering if its probably just the clutch pedal that messed up or what. how much does it cost to tow about 15 miles?
looks as if you need to bleed your clutch line. there is air in the line somewhere, possibly coming from a leak if it just happened and you didnt mess with anything. bleed the line first, that should do the trick, if not, there is a leak somewhere
dammit, it just feels like the clutch pedal died......and is it normal to not be able to force it into gear without a clutch?
.adam.
Jul 1, 2008 11:21 AM
