95 gsr cluster into ef
Old Mar 27, 2005 | 08:49 PM
PURPLETERROR aka BIGMATT's Avatar
Default 95 gsr cluster into ef
Has anyone done this? Or does anyone have the wiring diadram, any help is appreciated. I have the cluster, wiring pigtails, and vss, just need the wiring diargam now.
Thanks
Old Mar 27, 2005 | 08:55 PM
civicdust's Avatar
Default Re: 95 gsr cluster into ef (PURPLETERROR)
dont do it!
Old Mar 27, 2005 | 09:07 PM
kaoss_11's Avatar
B A N N E D
Anything can be done time and effort is what matters
Old Mar 28, 2005 | 01:58 PM
bump for knowledge
Old Mar 28, 2005 | 03:41 PM
FalkenSiR's Avatar
» Search Results
Your search for gsr cluster returned 64 results.
https://honda-tech.com/zerothread?id=1153085
Old Mar 28, 2005 | 06:59 PM
Default Re: 95 gsr cluster into ef (fast88std)
Wow, thanks for the useless search post, Ive already done that and found nothing. Hopefully the next person has something worthwhile to post.
Old Mar 28, 2005 | 09:01 PM
civicdust's Avatar
the acura and crx wires match up. so putting the cluster in is easy (atleast for me)
for the vss, u have to remove the cover on the tranny that the VSS cable goes to, and put the electronic one. run wires to the vss and ur done.
Old Mar 28, 2005 | 10:38 PM
Default Re: 95 gsr cluster into ef (See Our Ex)
so the colors are the same on both harnesses?
Old Mar 28, 2005 | 10:54 PM
88ED8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by See Our Ex &raquo;</TD></TR><TR><TD CLASS="quote">dont do it! </TD></TR></TABLE>
Why, I did mine and it looks soo mofuK!ng serious!
Old Mar 29, 2005 | 01:34 AM
Modified Motors's Avatar
Default Re: 95 gsr cluster into ef ('89ED8)
Mine took a few hours to wire.
Old Mar 29, 2005 | 02:01 AM
Magick211's Avatar
Default Re: 95 gsr cluster into ef (Modified Motors)
Ok man this gets asked every other day, if you search the right way you will the info plus 100 times morea than you are looking for
Old Mar 29, 2005 | 05:59 AM
sullenht's Avatar
Default Re: 95 gsr cluster into ef (Magick211)
I have done this upgrade my self. you will have to trim away some of the cluster and in the dash to make it fit. The only problem i have is when i fill my car up it only shows half a tank. good luck on the install.
Old Mar 29, 2005 | 10:26 AM
GSRCRXsi's Avatar
Default Re: 95 gsr cluster into ef (sullenht)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sullenht &raquo;</TD></TR><TR><TD CLASS="quote">I have done this upgrade my self. you will have to trim away some of the cluster and in the dash to make it fit. The only problem i have is when i fill my car up it only shows half a tank. good luck on the install.</TD></TR></TABLE>
you either did something wrong or your cluster or tank floater is messed up. mine works fine and goes all the way to F when i fill it up.
as far as wiring diagrams, i find pretty much all of the online ones useless and innacurate. make it easy on yourself and trace the back of the cluster to see where everything goes. that way you will be assured that everything works. its not hard to figure out what wires do what once you look at the back of the cluster.
Old Mar 29, 2005 | 10:48 AM
sullenht's Avatar
Default Re: 95 gsr cluster into ef (GSRCRXsi)
on the old cluster it was fine it showed full. everything is wired correctly I am unsure why that happend. all connections are solid no crimps just solder.
Old Mar 29, 2005 | 10:52 AM
GSRCRXsi's Avatar
its probably the cluster then
Old Mar 29, 2005 | 11:06 AM
ALX's Avatar
ALX
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PURPLETERROR &raquo;</TD></TR><TR><TD CLASS="quote">Wow, thanks for the useless search post, Ive already done that and found nothing. Hopefully the next person has something worthwhile to post.</TD></TR></TABLE>
this one thread alone has all the info https://honda-tech.com/zerothread?id=274235
usefull links in that thread in case it is usless in your opinion
http://www.angelfire.com/dc/oregonimport/gsr.html
https://honda-tech.com/zerothread?id=581283
http://www.4thgenerationcivic.com/ (click on how-to scroll down to Integra Cluster Install)
if this plethora of information doesnt help hit me up and ill scan and email you the pinouts your having problems with from my DC or EF shop manuals. Ive done this as have many others one H-T. Its easy enough if you know how to solder and keep track of 25 wires. One thing none of these mention is there is an extra connector on the gsr cluster that (yellow) is usless.
Modified by ALX at 2:22 PM 3/29/2005
Old Mar 29, 2005 | 11:44 AM
GSRCRXsi's Avatar
Default Re: 95 gsr cluster into ef (ALX)
theres a few extra wires on the gsr cluster.
the one for the MIL is useless
the one for the gas light is useless.
edit i misread what you said. the yellow conector is for the abs so yea thats the useless one.
but now you know youll have extra wires too
Old Mar 29, 2005 | 01:19 PM
Alx, thankyou for the info
ha...tch
May 23, 2008 08:54 AM
Spectrum24x
Sep 12, 2006 11:05 PM
civictyper04
Dec 26, 2005 08:36 AM
importboi22
May 31, 2004 10:32 PM
ironchef25
21
Jan 17, 2004 04:58 PM
