Suspension & Brakes Theory, alignment, spring rates....
New springs are noisey!
Old Mar 27, 2005 | 08:40 PM
zumiez007's Avatar
Default New springs are noisey!
I got some new neuspeed race springs and they are quite noisey over every minor road imperfection. I do have stock shocks, and am in the process of getting new ones, so I know that will help. But I read somewhere about wraping the bottom few coils with silicone. Does anyone know what i'm talking about or what type of product would help out this noise?
Modified by zumiez007 at 11:40 AM 3/28/2005
Old Mar 28, 2005 | 10:40 AM
zumiez007's Avatar
Default Re: New springs are noisey! (zumiez007)
bump
Old Mar 28, 2005 | 10:42 AM
MattD@Stoptech's Avatar
Springs are making noise? How so? On stock perches?
Old Mar 28, 2005 | 10:50 AM
zumiez007's Avatar
Default Re: New springs are noisey! (El Pollo Diablo)
yes, on stock shocks/perches. It sounds like they are rattleing around and creaking.
Old Mar 28, 2005 | 05:51 PM
Mike D's Avatar
bump, got the same problem with my gc/konis
Old Mar 28, 2005 | 08:06 PM
haveaniceday's Avatar
neuspeed race has inactive coils in return make noises to me i think its no big deal but can be rather annoyin sometimes.. to add another thing i suggest new shocks the koni sp3s are super nice and pricy but worth it ...stock ones wont hold up long with the drop.. also a camber kit.. this may not help the noise but just suggestions
Old Mar 28, 2005 | 08:19 PM
zumiez007's Avatar
Default Re: New springs are noisey! (haveaniceday)
I am planning on getting new shocks and I have a camber kit. The springs just seem to chatter as I drive down the road. I saw somebody use one of those plastic wire looms around several of the coils. Any other suggestions?
Old Mar 28, 2005 | 08:41 PM
vtecvoodoo's Avatar
Future Texas Boy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zumiez007 &raquo;</TD></TR><TR><TD CLASS="quote">I got some new neuspeed race springs and they are quite noisey over every minor road imperfection. </TD></TR></TABLE>
This is why we tube the progressive coils on our Pro-Kit and sportline units.
Ryan
Old Mar 28, 2005 | 08:49 PM
zumiez007's Avatar
Default Re: New springs are noisey! (vtecvoodoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecvoodoo &raquo;</TD></TR><TR><TD CLASS="quote">
Ryan</TD></TR></TABLE>
Please explain exactly what you are talking about? Tube? Is this something that comes with the springs or you added on later. I appologize for not being so wealthy that I can afford to drop loads of money on such kits.
Old Mar 28, 2005 | 08:52 PM
vtecvoodoo's Avatar
Future Texas Boy
We basically put a poly tubing over coils that may touch and cause the noise you are describing.
Our Pro-Kit and/or Sportline would be about the same price as your Neuspeed kit (we could be a little more).
Please explain exactly what you are talking about? Tube? Is this something that comes with the springs or you added on later. I appologize for not being so wealthy that I can afford to drop loads of money on such kits.</TD></TR></TABLE>
Old Mar 28, 2005 | 08:57 PM
zumiez007's Avatar
so, to clarify, having this tubing would cause, or eliminate the chatter sound?
Old Mar 29, 2005 | 02:16 PM
im sure it wouldnt hurt...
Old Mar 29, 2005 | 02:40 PM
Tyson's Avatar
looking at how many "dead" coils neuspeed uses in its design, i can see why there would be a lot of metal-metal contact noise. but i think using some kind of tubing or spacer would increase the ride height as well. maybe not a bad idea, just a consideration. heck, use it to your advantage to set your ride hieghts even....
Old Mar 29, 2005 | 03:43 PM
nonsense's Avatar
look at #6 ... these came on EKs
Old Mar 29, 2005 | 04:01 PM
Tyson's Avatar
Default Re: New springs are noisey! (nonsense)
the rubber collars were also present in my crx stock springs.
Old Mar 29, 2005 | 06:24 PM
zumiez007's Avatar
Default Re: New springs are noisey! (Tyson)
ok, the backs have those, but not the front. Any suggestion on a type of tubing to use?
Old Apr 1, 2005 | 06:04 PM
Haruspex's Avatar
Im not sure how well this would work but perhaps you could spray on some kind of rubberized coating on the coils, something like spray on beadliner. It might be easier than trying to slip rubber tubing down the spring.
power11
Suspension & Brakes
May 18, 2007 06:42 AM
()()DC2
Feb 2, 2007 10:35 PM
multitracks
15
May 19, 2005 04:28 PM
vtec lude3
Oct 5, 2004 03:38 PM
Subtle
Jan 27, 2002 12:29 PM
