Valve noises
Old Mar 27, 2005 | 08:19 PM
wragen22's Avatar
Default Valve noises
After a while of speculating what the rythmetic ticking could be, I've come to the conclusion that my valves are whats making the noise. I can hear them most when I let off the gas at lower speeds. I can also make out the sound of a more vigorous ticking as I'm accelerating. Any ideas as what I should do about this, and how much it might cost me to fix it?
Old Mar 27, 2005 | 08:25 PM
ridexstraight's Avatar
Default Re: Valve noises (wragen22)
well check your oil, it could just b a simple lifter tick??????
Old Mar 27, 2005 | 08:42 PM
momstaxi's Avatar
sounds like you need a valve lash adjustment. get a haynes or chiltons manual for you car and it will give you directions on how to go about it yourself, its very easy, the only tools you'll need besides a socket set are a set of feeler gauges. as far as getting one done im not positive but i believe i've heard anywhere from the 60+dollars for one, not sure though. but like i said, id reccommend that you do it yourself due to the simplicity of the task..
Old Mar 27, 2005 | 11:25 PM
goowakjai
Guest
Posts: n/a
Default Re: Valve noises (momstaxi)
i have the same problem too, i asked my auto shop[ teacher wut he thot of it, he said for a car as old as mine(95 with 88K miles) its really common, and though it can be fixed, there wudnt be any perforamnce benefits, but the sound still makes me and my dad un easy, so we got a haynes book and plan on fixing it sometime, though its been weeks and we cant seem to get our lazy asses to do it
Old Mar 28, 2005 | 08:09 AM
accordion's Avatar
Default Re: Valve noises (goowakjai)
For what it's worth, I'm having a similar problem on my '95 LX. It happens only on acceleration, and it's a slight ticking sound.
Old Mar 28, 2005 | 09:50 AM
flight50's Avatar
Default Re: Valve noises (accordion)
I have the same problem with my car. I went by a local mod shop and right away he told me that the ticking was because by valves needed to be adjusted, $125 to adjust them. honda didn't make hydraulic adjusters so they recommend 15-30k before you need an adjustment. it also depends on if whether they are highway miles or around town miles.
Old Mar 28, 2005 | 11:03 AM
alotawatts's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goowakjai &raquo;</TD></TR><TR><TD CLASS="quote">i have the same problem too, i asked my auto shop[ teacher wut he thot of it, he said for a car as old as mine(95 with 88K miles) its really common, and though it can be fixed, there wudnt be any perforamnce benefits, but the sound still makes me and my dad un easy, so we got a haynes book and plan on fixing it sometime, though its been weeks and we cant seem to get our lazy asses to do it</TD></TR></TABLE>
You need a new shop teacher. Even though slight valve adjustments may not make a noticable change in performance it will certainly give your engine longer life and improve your milage.
Modified by alotawatts at 3:03 PM 3/29/2005
Old Mar 28, 2005 | 10:17 PM
CB7VTEC's Avatar
Default Re: Valve noises (alotawatts)
...not to mention the change in emissions if they're really bad, since you (orig. poster) live in CA.
Old Mar 29, 2005 | 10:45 AM
13lue's Avatar
Do you guys use regular motor oil or you guys use Synthetic? Can that be a solution?
Old Mar 29, 2005 | 11:03 AM
JonnySBeee...'s Avatar
same problem, pisses me off hella bad, i can hear the ticking more than the exhaust, haha getting it changed by my friend with a shop for 45
Old Mar 29, 2005 | 02:06 PM
alotawatts's Avatar
Injectors make a faint clicking also.....normal
Old Mar 29, 2005 | 04:31 PM
goowakjai
Guest
Posts: n/a
Default Re: Valve noises (13lue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 13lue &raquo;</TD></TR><TR><TD CLASS="quote">Do you guys use regular motor oil or you guys use Synthetic? Can that be a solution?</TD></TR></TABLE>
i use regular, but plan on switching to sythetic(mobil 1) on next oil change...we're all pretty positive, if not complete sure, that it needs a valve adjustment, but im guessing if u switch to syn the noise myte go down a lil cuz i have heard of engine noise decreasing when people switch to synthetic
Old Mar 29, 2005 | 06:10 PM
jagged4698's Avatar
I may have to check mine out... what did he mean by "feeler guages" what are those exactly?
Old Mar 29, 2005 | 08:10 PM
goowakjai
Guest
Posts: n/a
Default Re: Valve noises (jagged4698)
feeler guages are just really thin and accuarate sheets of metal used to measure really small spaces...usually to a thousandth of an inch (ex: .009 inch)
Old Apr 3, 2005 | 04:05 PM
wragen22's Avatar
I went and got my valves adjusted at the dealership for $116. However I noticed the noise was still there this morning when I went for a drive. Any suggestions on what I should do next? My father and I thought for sure it was the valves.
Maybe its just the injectors like alotawatts said.
iloyola
Jul 27, 2005 01:53 PM
Stealthman80
Jul 25, 2005 07:23 AM
XenonDepot
Apr 18, 2003 12:44 AM
HuskerHybrid
Mar 12, 2003 09:23 PM
Yuleluder
Aug 29, 2002 07:20 PM
