h22 auto 2 manual conversion
i am doin a h 22swap in my car and had an auto im j/w if i need to get the prelude manual stuff or if the accord manual stuff will all bolt up and exactly what all i need...thnx
its a 95 accord and im doin the jdm swap...so i should use all the accord parts or get the prelude parts?........what about engine wiring harness since its an auto will it be all wack *** weird since im converting to manual
with a 5th gen, for the most part everything will off a 92-96 lude will work. just the axle, mounts, halfshaft, brake pedal are accord specific. ive got mostly all 92 accord 5spd parts in my 5th gen except the tranny.
1. 5 speed transmission (F22, F23, H22, H23)
2. 5 speed starter (90-02 Accord 92-02 Prelude)
3. 5 speed shifter assembly w/ shifter cables (90-97 Accord 92-96 Prelude)
4. 5 speed drivers side axle (your year accord, but from 5-spd version)
5. 5 speed intermediate shaft (your year accord, but from 5-spd version)
6. 5 speed clutch pedal assembly (90-97 Accord 92-96 Prelude)
7. 5 speed brake pedal arm (90-97 Accord 92-96 Prelude)
8. Clutch master cylinder w/ reservoir (90-97 Accord 92-96 Prelude)
9. Clutch line from Clutch master cylinder to clutch dampener (90-97 Accord 92-96 Prelude)
10. Clutch dampener assembly (90-97 Accord 92-96 Prelude)
11. Clutch line from Clutch dampener to 5 speed tranny (90-97 Accord 92-96 Prelude)
12. Clutch line from 5 speed tranny to slave cylinder (90-97 Accord 92-96 Prelude)
13. Slave cylinder (90-97 Accord 92-96 Prelude)
14. Clutch (90-02 Accord 92-01 Prelude)
15. Flywheel (90-02 Accord 92-01 Prelude)
16. 5 speed mount (Your year, 5-spd version)
17. 5 speed mount bracket (go to honda - tell them to look for the bracket that is welded on the car - part is S.O.P and costs 15-25.00) (see notes)
18. MIG WELDER (see notes)
19. BOLTS: 8 Flywheel Bolts, 6 Pressure Plate Bolts, 3 Intermediate Shaft Bolts, 1 Long Tranny Bolt
THEROPE
Mar 3, 2014 05:36 AM
skingfreak
May 4, 2007 08:34 PM
hondaboy92
Apr 22, 2005 06:37 AM
seeNATgo
Oct 16, 2002 11:13 AM
