OK guys a Maxbore gsr TB vs stock gsr how much hp after tuneing?
Old Mar 27, 2005 | 06:29 PM
JunkyardDog's Avatar
Default OK guys a Maxbore gsr TB vs stock gsr how much hp after tuneing?
Thinking about doing the maxbore thing for reliability cold starts ect oh and the money. Let me know
Old Mar 27, 2005 | 06:35 PM
asubennett's Avatar
Default Re: OK guys a Maxbore gsr TB vs stock gsr how much hp after tuneing? (JunkyardDog)
Depends on your motor mods. How bad is your current TB choking your motor. On a built 2 liter motor- maybe 7-10hp. On a bolt on type stock motor 1-2 hp if any at all.
Old Mar 27, 2005 | 06:45 PM
Default Re: OK guys a Maxbore gsr TB vs stock gsr how much hp after tuneing? (asubennett)
1.8 moderate build
got some oil burning (1 quart every 2k)problems had good Ring gaps during build have you guys had any problems like this.
Old Mar 27, 2005 | 06:51 PM
asubennett's Avatar
How did you go about breaking the motor in? And what grit stone was used by your machine shop for the finish hone.
Old Mar 27, 2005 | 06:57 PM
kept it out of vtec for 2k, then dipped into it but not abusive I don't think but these things were not designed to go 8500+ so I was just wondering if it was a regular thing. I am probably not going to pull the motor unless it gets bad.
The car runs a little cold so it might be then that its burning but I am not sure cause its not allot.
Old Mar 27, 2005 | 07:43 PM
Used2beAb16's Avatar
All i can say to you is max-bore does a hell of a job.
Old Mar 27, 2005 | 07:46 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JunkyardDog &raquo;</TD></TR><TR><TD CLASS="quote">kept it out of vtec for 2k, then dipped into it but not abusive I don't think but these things were not designed to go 8500+ so I was just wondering if it was a regular thing. I am probably not going to pull the motor unless it gets bad.
The car runs a little cold so it might be then that its burning but I am not sure cause its not allot.</TD></TR></TABLE>
If you beat on it frequently at 8,500rpms+ then its GOING to use some oil. Period. Do a search on it, you will find the R owners have the same "problem". Honda released a bulletin on it stating it was "normal" for the DOHC Vtec engines to consume some oil with extended high rpm use.
Old Mar 28, 2005 | 03:51 AM
teefunk01's Avatar
Default Re: OK guys a Maxbore gsr TB vs stock gsr how much hp after tuneing? (Hybrid93Eg)
do you guys have the max bore site link again?
Old Mar 28, 2005 | 08:44 AM
Hybrid96EK's Avatar
Default Re: OK guys a Maxbore gsr TB vs stock gsr how much hp after tuneing? (tphan4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tphan4 &raquo;</TD></TR><TR><TD CLASS="quote">do you guys have the max bore site link again?</TD></TR></TABLE>
Umm... http://www.maxbore.com
Old Mar 28, 2005 | 09:00 AM
Thanks for the info on oil burning, I'm doing the max bore thing also I spoke with him for a little while and he knows what he is doing.
Old Mar 28, 2005 | 08:09 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JunkyardDog &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the info on oil burning, I'm doing the max bore thing also I spoke with him for a little while and he knows what he is doing. </TD></TR></TABLE>
Its a safe invesment mine came out perfect, 69mm tapered to 65. (b16)
Old Mar 28, 2005 | 09:43 PM
hybrid_vtec's Avatar
Default Re: OK guys a Maxbore gsr TB vs stock gsr how much hp after tuneing? (Used2beAb16)
I had mine bored to 64mm. Its a work of art!
Old Mar 30, 2005 | 05:38 PM
Turbo_Mike's Avatar
Default Re: OK guys a Maxbore gsr TB vs stock gsr how much hp after tuneing? (hybrid_vtec)
didnt he use to have a chart on his website that said the size of each TB and then what he bored it to?
I've been searching for an hour and cant find the info1! wtf!
Old Mar 31, 2005 | 05:51 AM
Default Re: OK guys a Maxbore gsr TB vs stock gsr how much hp after tuneing? (razor ron)
Off the maxbore web site and also an e-mail he sent me.
I havent gotten mine back yet but I am looking foward to it.
{I can convert your First gen JDM B16 throttle body to ITR specs
I can convert your non VTEC integra throttle body to ITR specs
I can make your GSR or DOHC Civic Si throttle body to 2mm over ITR specs
I can turn your ITR throttle body to a massive 65mm and taper out to 70mm
Here is a list of the size you can expect to get your throttle body bored out to:
D series up to 60mm.
B series from 62mm to 65mm depending on year and engine.
H series up to 66mm depending on year and engine.
K series up to 65mm.
F series up to 64mm. }
E-Mail {Honda/Acura Throttle Body Inside Diameters (in mm)
b18c1 60
b18c spec R 62
b18a 58
b18b 60
b16a SiR 58
b16a Sir2 / b16a2 60
b16a3 58
b20b/z 60
f20c 62
d15b7 56
d16a6 55
d16y7 56
d16y8 56
d16z6 56
ZC 55
d16a1 55
d16a8 55
h22a / h23a 60
f22 / f23 60}
Old Mar 31, 2005 | 06:16 AM
Turbo_Mike's Avatar
if a b18b tb is 2mm bigger than an sir tb, then wouldnt that be 2mm bigger than itr?
Bsharpe
Jan 18, 2010 01:58 PM
VTECsound.
21
Nov 22, 2005 01:33 PM
DC2SIR-G
Oct 18, 2005 07:54 AM
gliaw
Nov 3, 2002 08:11 PM
