Antenna question
Old Mar 27, 2005 | 06:17 PM
djtony5's Avatar
Default Antenna question
Hey guys, I just recently installed a new Pioneer deck, everything went fine, except that whenever I turn on the radio my antenna won't go up. I know the wire for the antenna is green with yellow stripe on the harness, but how should I go about raising it up when the radio is on.
Old Mar 27, 2005 | 06:23 PM
skleats's Avatar
I had this problem when I put in my Pioneer head unit. I don't remember offhand which wire on the unit I connected to power the antenna, but it was light blue. I would go look, but there's a monsoon right now and I'm lazy. I've had it hooked up this way for over a year now with no problems. Good luck.
Old Mar 27, 2005 | 07:26 PM
Pythagoras's Avatar
Default Re: Antenna question (djtony5)
screw the antenna....it looks retarted heeping off the back of an integra trunk. I purposley cut my antenna wire when I got a new deck. I still get excellent radio reception. Best of both worlds
Old Mar 27, 2005 | 07:30 PM
njandrewg's Avatar
Default Re: Antenna question (Pythagoras)
i disabled my antenna too(with a switch), but reception is pretty shitty..but i only listen to cds anyways so no cares
Old Mar 27, 2005 | 07:59 PM
bigkshep's Avatar
i got the same problem, my antenna wont go up after i installed my cd player. i dont want it to go up anyways because i always listen to cds. but its the principle of the thing
Old Mar 27, 2005 | 09:15 PM
kimo98GSR's Avatar
Default Re: (bigkshep)
Shave the antenna and get XM radio.
Old Apr 1, 2005 | 05:42 PM
Vera's Avatar
Default Re: (kimo98GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kimo98GSR &raquo;</TD></TR><TR><TD CLASS="quote">Shave the antenna and get XM radio.</TD></TR></TABLE>
Old Apr 1, 2005 | 05:49 PM
taltares's Avatar
hook the blue with white stripe up to the power antenna wire
Old Apr 1, 2005 | 06:37 PM
crazyd's Avatar
Default Re: Antenna question (taltares)
had the same problem when it was professionally installed. I took it back and they did it in less than 10 min!
I'm getting my XM though soon! The shop has a blow-out sale, the kit is selling for $20 after rebate (The unit + the brain)!!!
Old Apr 1, 2005 | 06:46 PM
b-power's Avatar
Right On !
Old Apr 1, 2005 | 07:06 PM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by taltares &raquo;</TD></TR><TR><TD CLASS="quote">hook the blue with white stripe up to the power antenna wire</TD></TR></TABLE>
Old Apr 1, 2005 | 07:11 PM
numbnuts22715's Avatar
Default Re: Antenna question (crazyd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyd &raquo;</TD></TR><TR><TD CLASS="quote">had the same problem when it was professionally installed. I took it back and they did it in less than 10 min!
I'm getting my XM though soon! The shop has a blow-out sale, the kit is selling for $20 after rebate (The unit + the brain)!!! </TD></TR></TABLE>
holy crap.. that is pretty cheap... is this a big store or just a small shop in your area?
Old Apr 1, 2005 | 07:45 PM
VINtegra90's Avatar
Default Re: Antenna question (numbnuts22715)
it could be worse.. ur teg's antennae could be stuck UP.. looks terrible
Old Apr 1, 2005 | 07:51 PM
.brian.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pythagoras &raquo;</TD></TR><TR><TD CLASS="quote">screw the antenna....it looks retarted heeping off the back of an integra trunk. I purposley cut my antenna wir</TD></TR></TABLE>i just unplugged the harness today, so now i dont have that stupid *** antenna up. what is the point of having the antenna up when your listening to cd's? and i never listen to the radio.
Old Apr 1, 2005 | 07:54 PM
VINtegra90's Avatar
Default Re: Antenna question (i luv my 97 ls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i luv my 97 ls &raquo;</TD></TR><TR><TD CLASS="quote">i just unplugged the harness today, so now i dont have that stupid *** antenna up. what is the point of having the antenna up when your listening to cd's? and i never listen to the radio.</TD></TR></TABLE>
weerrrrrrd
Old Apr 1, 2005 | 08:30 PM
RIX982DRLS's Avatar
I had the same problem with my pioneer head unit. I ended up buying a s2k antenna (not a power antenna) from honda for $27, and an install kit for $15 from a fellow HT'er. Install took 45mins. Looks a lot better in my opinion. good luck either way.
Old Apr 2, 2005 | 08:41 AM
XplodeTeg's Avatar
what is the other yellow and blue wire i see at the driver side that is little bigger than the antenna wire? my friend cut that wire first but it didnt work.
Old Apr 2, 2005 | 10:47 AM
96grngsr's Avatar
yea, i ran into the same problem when installing my pioneer head unit with my 6 channel amp... but after a little figuring out... i hooked up the brown/white from the oem harness to the blue/white or blue from the radio harness, but then again it also depends on the year of your car as well since the 97+ harness is different than years before it..
try this link
http://www.installdr.com/Harnesses/HA-Wiring.pdf
Salvi-EJ1
Jul 5, 2012 08:34 PM
MurtazaDSM
Audio / Security / Video
10
Mar 29, 2011 05:08 PM
V-Thang
Jul 23, 2004 09:45 PM
slowacura
Mar 16, 2004 10:04 PM
TSAngry
Feb 26, 2004 01:16 PM
