viper 1000 remote start
Old Mar 27, 2005 | 05:16 PM
theish05's Avatar
Default viper 1000 remote start
does anyone have any ideas on how to hook up a remote start i know about bypassing the clutch and stuff. if any one with a honda and a viper alarm has done this please help
that would kick ***.
thanks
Old Mar 27, 2005 | 05:28 PM
camo hatch's Avatar
Default Re: viper 1000 remote start (theish05)
do you just need to know the whole process? or are you just not sure about bypassing the cltch switch? i can help out either way.
Old Mar 27, 2005 | 05:32 PM
DALE-EK4's Avatar
Default Re: viper 1000 remote start (camo hatch)
yea what do u need to know?
Old Mar 27, 2005 | 05:47 PM
camo hatch's Avatar
assuming you need to know how the whole process goes
first, you'll need a wiring diagram in order to hook all the right wires. (ie: starter, ignition, constant 12v, brake, etc.) make sure you've got a good set of auto-strippers and crimpers, it will make your job alot easier.
next get a drop/shop light, you will be on your back and upside down and in the dark for most of this job.
if this is an alarm unit, make sure to loom or wrap up your wires nicely to look inconspicuous and mount the "brain" somewhere other than right in plain sight, so if a theif got in your car, he'd have a little trouble findind the brain. the passenger side is a nice choice.
most of all, make sure you have the right parts and tools!
any questions on the specifics, or getting a diagram on the car...PM or email me.
Old Mar 27, 2005 | 05:59 PM
theish05's Avatar
ok i have a hanes repiar man with all the wiring diagrams and strippers,tools, etc.. i need more help with the viper unit itself eveything is hooked up but the remote start. what i need to know is what wires do what from the alarm. do have to use a channel operation (5,6 etc..like it could go to a sunroof or so) or the three green wires that are listed- starter wire common/starter wire normaly open/ starter wire normaly closed.
Old Mar 27, 2005 | 06:04 PM
camo hatch's Avatar
the other channels go to nothing, unless you know know how to wire up relays and window modules or the like. the 3 greens go nowhere on a honda, unless adding some other relays that require a starter input. if youve got everything wired up..all you should need to do...in theory, is program the unit, make sure you set it to run in "tachless" mode if you havent tapped a tach signal wire, if you havem you need to learn the tach signal in the programming mode.
edit** figured out your green wires for ya....just wire it up like so...
ignition switch --------x x----------starter motor
..............green/white green/black
so..cut the starter wire, run green/white to key side and green/black to motor side.
you do NOT need to use your H2 harness, with the extra channel outputs.
Old Mar 27, 2005 | 06:14 PM
theish05's Avatar
umm.. ok it is all hooked up... ill get to work on it
i guessin now that i have to get like a piggy back for the alarm. because im think mabye its not made with it that remote start option. that would explain why it has absolutily no directions for it. but it is on the box and in the owners guide just not it the instilllation guide umm..ill figure it out. if anymore questions come i know where to go.
Old Mar 27, 2005 | 06:15 PM
theish05's Avatar
ohhhhhhhhhhhhhhh ok thats all i needed to see perfect your the man
Old Mar 27, 2005 | 06:17 PM
theish05's Avatar
theres also just a green wire in that harness? mabye a ground.
and what the hell do i push on the remote to get it to work. ahh...i love this stuff.
Old Mar 27, 2005 | 07:44 PM
theish05's Avatar
Default Re: (theish05)
yea if you find any info on the third wire (starter wire normal open) or how to turn on with remote let me know.
Old Mar 28, 2005 | 05:57 AM
camo hatch's Avatar
you do NOT need to use the solid Green wire on the immobilizer harness (Starter Wire Normally Open) just cut it off the harness. Civics and most cars in general use a Normally Closed circuit for the starter wire. if you are talking about the solid Green wire on the main (H1) harness, that's the Negative Door Trigger input and would be wired to the wire that drops volatge out to ground when the doors are open, and plays a pretty big role in actually protecting your car.
also, the Viper 1000 is not a remote start unit, just keyless entry and security.
for 92-95 civics the door trigger is
Door Trigger\\lt. green/red\\driver kick panel
for 96-00 civics
Door Trigger\\ lt. green/red\\factory alarm plug
both are negative trigger
if you want to add Remote Start...which i don't recommend on a Manual tranny car, for safety reasons, you can just buy a Viper 130XV unit and piggy back it to work with your 1000.
solesthatgo
Apr 23, 2010 08:30 PM
IOSUA
Oct 8, 2007 02:19 PM
BlUeDC2nEr
Audio / Security / Video
11
Dec 28, 2005 10:18 AM
Junkyard2000
Jul 4, 2005 10:08 PM
GsrSdn
11
Aug 23, 2002 09:13 PM
