Q about mugen shift knob
Old Mar 27, 2005 | 04:32 PM
Nihilus's Avatar
Default Q about mugen shift ****
Awhile back I bought a mugen shift **** for 1990 CRX Si with Skunk2 short shifter. This may be a trivial point to some but I figured I would at least see if this has happened to anyone else. When I first put the **** on the mugen logo faced the passenger side door. This was at with the **** twisted as tight as it would go. Since then I haven't thought of it much but I have noticed that if I twist as hard as I can the **** will rotate another millimeter or so. I would idealy like the logo to face straight to the back of the car. Actually on my old CRX also with skunk2 shifter I had the same **** but didn't encounter this problem. Is there anything I can do?
Old Mar 27, 2005 | 04:38 PM
Burlyirishdude's Avatar
Default Re: Q about mugen shift **** (Dark Zachiel)
keep twisting until you strip it....
i haven't run into that problem....you sure you shiftlinkage is in the right direction...i kn ow that sounds stupid...but sometimes they kinda rotate or after a swap they are backwards(especially if you don't remember which way the bend in the shifter went)....that's the only think i can think of..
Old Mar 27, 2005 | 04:48 PM
doublethink's Avatar
you could take it all the way off, then try to re install it a few times to see if the direction of the logo changes at all.
if it varies then you just have to find the right starting point, if not then you could keep twisting it until its where you want it, but as stated above beware of stripping.
Nihilus's Avatar
Default Re: Q about mugen shift **** (Burlyirishdude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Burlyirishdude &raquo;</TD></TR><TR><TD CLASS="quote">keep twisting until you strip it....
i haven't run into that problem....you sure you shiftlinkage is in the right direction...i kn ow that sounds stupid...but sometimes they kinda rotate or after a swap they are backwards(especially if you don't remember which way the bend in the shifter went)....that's the only think i can think of..</TD></TR></TABLE>
Well a friend of mine had a 2000 Si and had the same problem. he never did anything about it tho
Old Mar 27, 2005 | 04:59 PM
2nxcrx's Avatar
You need a special nut underneath it so the shiftknob screws down to the nut not the bottom of the threads then you adjust the nut so the logo sits right. It probably should have come with it.
Old Mar 27, 2005 | 05:00 PM
2nxcrx's Avatar
I can take a picture of mine if you'd like.
Old Mar 27, 2005 | 05:08 PM
Nihilus's Avatar
Default Re: (2nxcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2nxcrx &raquo;</TD></TR><TR><TD CLASS="quote">You need a special nut underneath it so the shiftknob screws down to the nut not the bottom of the threads then you adjust the nut so the logo sits right. It probably should have come with it.</TD></TR></TABLE>
The **** screws down WAY below where a nut on the shifter could go even at lowest setting.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublethink &raquo;</TD></TR><TR><TD CLASS="quote">you could take it all the way off, then try to re install it a few times to see if the direction of the logo changes at all.
if it varies then you just have to find the right starting point, if not then you could keep twisting it until its where you want it, but as stated above beware of stripping.</TD></TR></TABLE>
I've tried this a million times no-go. I've been told that I could use lock-tite or whatever it's called on the shifter. Takers? <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2nxcrx &raquo;</TD></TR><TR><TD CLASS="quote">I can take a picture of mine if you'd like.</TD></TR></TABLE>
Thanks but no thanks...
Old Mar 27, 2005 | 05:10 PM
Creepshow S60's Avatar
Default Re: (Dark Zachiel)
i have this "issue" with my "mugen" shift **** as well. it's a $25 dollar **** from ebay. i've had two of them before and both times the logo angles towards the passenger side door.
Old Mar 27, 2005 | 05:13 PM
Nihilus's Avatar
Default Re: (y-49CRX)
Ok I'm leaning more towards this using lock-tite idea. I guess one of the guys on the aRgh forum did this. Question though....if I need to take the **** off how difficult would that be with the lock-tite? again, takers on the idea of lock-tite?
BTW- for those encountering the same problem as me I was instructed to put some llock-tite on the shifter and screw the mugen **** on as tight as possible while the logo faces where you want it to go.
Old Mar 27, 2005 | 05:19 PM
TurtleEF3's Avatar
my shiftknob came with a nut that i screwed onto my dc sports shifter
and then just tightened the screw until my **** faced the right direction.
But i dont have a mugen **** mine's just a fake type r ****.
Old Mar 27, 2005 | 05:21 PM
2nxcrx's Avatar
There's actually a honda oem part for this but screw it not worth my time typing it out.
Old Mar 27, 2005 | 05:22 PM
2nxcrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFcivicHB &raquo;</TD></TR><TR><TD CLASS="quote">my shiftknob came with a nut that i screwed onto my dc sports shifter
But i dont have a mugen **** mine's just a fake type r ****.</TD></TR></TABLE>
That's exactly how I did it but better desciption.
Old Mar 27, 2005 | 05:31 PM
Nihilus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2nxcrx &raquo;</TD></TR><TR><TD CLASS="quote">That's exactly how I did it but better desciption.</TD></TR></TABLE>
Yeah but the thing is that the threads on the **** do NOT start at the bottom of the ****. The threading is half-way into the ****. If you try to screw the mugen **** on and leave some thread visible on the shifter there is about 1&1/2 threads useable. If you put a nut on it I'm sure the **** would just snap off.
Old Apr 4, 2005 | 06:01 PM
ShitBoxCrx's Avatar
heat the inside of the **** with a torch the screw it as far as it will go and we str8 and wait
Old Apr 4, 2005 | 06:07 PM
crx90rcr's Avatar
Default Re: (ShitBoxCrx)
u can use plumbers tape on it like one or 2 wraps around the threads keeps it from sqeeking and itl stay at the rite tightness
Old Apr 4, 2005 | 07:00 PM
Dosvita's Avatar
you are suppose to put a nut under the ****. i have never seen an aftermarket one that doesnt require the nut.
Old Apr 4, 2005 | 07:13 PM
DocSean's Avatar
Yeah man, just rock the jam nut.
Old Apr 4, 2005 | 07:20 PM
SiRAaron's Avatar
ya thats the correct way to do it
Old Apr 4, 2005 | 09:12 PM
DJ_SaNdOz's Avatar
Default Re: (SiRAaron)
You cn't use a nut:
Mine sits fine, I haven't used it in forever, mine is a knock off though.
Old Apr 4, 2005 | 09:39 PM
thenick's Avatar
Default Re: (DJ_SaNdOz)
https://honda-tech.com/zerothread?id=1193393
Weird
Old Apr 4, 2005 | 10:15 PM
sporkcrx's Avatar
Default Re: (thenick)
Cmon now, is it really that important where the logo faces
Old Apr 10, 2005 | 04:36 PM
Default Re: (sporkcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx &raquo;</TD></TR><TR><TD CLASS="quote">Cmon now, is it really that important where the logo faces </TD></TR></TABLE>
yes, for aerodynamic purposes.
Old Apr 10, 2005 | 05:37 PM
riceisnicenv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thenick &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1193393
Weird </TD></TR></TABLE>
LOL i was just about to go look for that exact thread... this is wierd
Old Apr 10, 2005 | 06:23 PM
Nihilus's Avatar
Default Re: (riceisnicenv)
I made that thread the same night I posted this after I figured it out...
ef93si
Jan 30, 2006 10:12 AM
216.226.142.95:27016
Dec 17, 2002 09:28 AM
Kengs
Nov 7, 2002 11:37 AM
Wiseguy
Aug 24, 2002 07:05 PM
