aftermarket differences in b16 question
just a question about the difference between the 92-93 integra xsi b16 jdm motor and the usdm civic b16 motor. both say they are obdI, but the integra motor is a lot cheaper. if i get the integra motor, are the aftermarket b16 parts going to be the same thing? like cams, pistons, bearings, timing belt, etc etc, or am i not going to be able to build up the integra motor? thanks for any input guys and/or gals.
the newer b16 motor claims to have about 10 more horses, which jacks up the price.
aftermarket parts are mostly the same.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublethink »</TD></TR><TR><TD CLASS="quote">the newer b16 motor claims to have about 10 more horses, which jacks up the price.
aftermarket parts are mostly the same.</TD></TR></TABLE>
Well that and the usdm motor could be newer/less mileage.
The parts your mentioned should be the same since the block has the same rod length, stroke and bore. The head should be mostly the same as well.
