obd conversion question
Old Mar 27, 2005 | 02:51 PM
gnar kill's Avatar
Default obd conversion question
ok.....when I got my car it had an oil pressure guage installed in it...this gauge is just plummed into the spot right above the oil filter (which I believe is the position of the knock sensor) and I can see I have a little plug just hanging out down there not connected to anything. How come I get no check engine codes?? Also on the JK obd conversion harness I am suppose to connect one of the wires to the knock sensor. Would I run into problems leaving it not hooked up seemings how my car runs pretty perfect right now??
Old Mar 27, 2005 | 02:53 PM
gnar kill's Avatar
Default Re: obd conversion question (gnar kill)
oh sorry my setup is a d16a6 which I am putting a z6 head, intake manifold and LS tb running a p28 ecu.
Old Mar 27, 2005 | 07:46 PM
gnar kill's Avatar
bump.....please help....
Old Mar 27, 2005 | 07:54 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gnar kill &raquo;</TD></TR><TR><TD CLASS="quote">I can see I have a little plug just hanging out down there not connected to anything.</TD></TR></TABLE>
Does the plug have a yel/red wire? If so then that went to the oil pressure switch. The previous owner must have removed it to install the oil pressure gage
D16a6 doesn't have a knock sensor and the p28 doesn' t look for it.
Old Mar 27, 2005 | 08:12 PM
Blown90hatcH's Avatar
Default Re: obd conversion question (eda6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 &raquo;</TD></TR><TR><TD CLASS="quote"> D16a6 doesn't have a knock sensor and the p28 doesn' t look for it.</TD></TR></TABLE>
Werd. No knock sensor required for the P28 ecu.
Old Mar 27, 2005 | 08:25 PM
gnar kill's Avatar
Default Re: obd conversion question (Blown90hatcH)
Sorry I am just confused...on my JK conversion harness it says I need to hook one of the wires into the one wire sensor just above the oil filter....,.I figured it was the knock sensor.....there is another sensor right above my oil filter with two wires comin out of it....sorry I am a noob....so I guess I just don't have to worry about hooking that wire up and I will be good right
Old Mar 27, 2005 | 10:37 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gnar kill &raquo;</TD></TR><TR><TD CLASS="quote">Sorry I am just confused...on my JK conversion harness it says I need to hook one of the wires into the one wire sensor just above the oil filter....,.I figured it was the knock sensor.....there is another sensor right above my oil filter with two wires comin out of it....sorry I am a noob....so I guess I just don't have to worry about hooking that wire up and I will be good right </TD></TR></TABLE>
That is used for reference about the general location of where a knock sensor is. It also says in your instructions that the knock sensor wire may not be needed and in your case it is not.
Jason
http://www.JKobd.com
Kprettyman
Oct 10, 2013 08:38 AM
JusAccord
Mar 14, 2012 09:23 AM
slowslow
Oct 18, 2009 01:26 PM
graftuner34
Mar 26, 2008 06:31 PM
wullie_vtec
22
Feb 8, 2006 01:52 PM
