one wire o2 sensor
Old Mar 27, 2005 | 09:07 AM
StreetEG's Avatar
Default one wire o2 sensor
I have a b16 swap, and apparently the civic cx has a 1 wire o2 sensor, and the b16 needs the 4 wire? How bad is it that I am drivin around without the 4 wire, and which should i replace it with if i need to? Im not throwing a cel...
Eric
Old Mar 27, 2005 | 09:17 AM
red91sit's Avatar
Default Re: one wire o2 sensor (StreetEG)
Hmm that's really strange your not throwing any codes, You should be throwing o2 codes since It's supposed to have a heater. If your not though it's no biggie, It's problby running just fine. Are you using a chipped P-28 ecu? Cuz the o2 sensor needs depend on the ecu not the motor.
Old Mar 27, 2005 | 09:22 AM
street dreams's Avatar
From: chillin in that city called queen creek, but homes the atl
did u use the cx harness on the b16
Old Mar 27, 2005 | 11:37 AM
StreetEG's Avatar
Default Re: one wire o2 sensor (street dreams)
IM not sure about the harness, but i do have a mugen prgram(****) chipped p28
Old Mar 27, 2005 | 02:36 PM
red91sit's Avatar
Tha'ts bizarre, have you driven this car for more than one hour at a time yet? I know with my Chipped P28 ecu sometimes it takes a looong time for hte CEL to come on.
Old Mar 27, 2005 | 03:11 PM
StreetEG's Avatar
Default Re: one wire o2 sensor (red91sit)
ya i drive it up and down from my college to jersey...an easy 2 hours and no cel...my gas milage sucks tho im thinkin this has somthin to do with it...im gettin one soon tho just to be sure... i hope the shop i got the swap at didnt just take out the bulb for my cel..... bastards
Eric
Old Mar 27, 2005 | 06:23 PM
StreetEG's Avatar
ttt...any idea of how this is affecting horsepower, gas milage, timing etc?
Old Mar 27, 2005 | 06:58 PM
red91sit's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StreetEG &raquo;</TD></TR><TR><TD CLASS="quote">ya i drive it up and down from my college to jersey...an easy 2 hours and no cel...my gas milage sucks tho im thinkin this has somthin to do with it...im gettin one soon tho just to be sure... i hope the shop i got the swap at didnt just take out the bulb for my cel..... bastards
Eric</TD></TR></TABLE>
I'm almost sure they did take out the bulb, Try disconnecting something and see if it throws a code. If it's just a bulb it won't be so bad, if it's a cut wire it could be a Pain In The butt to find unless it's right by the ECU .
BTW Right now my o2 sensor isn't plugged in and I get stumbling, it 8 cycles (fires every 4th revolution ) and gets HORRIBLE gas mileage. well like horrible for a civic, i mean it's like suv mileage. I think what happens is either the ECU gives it lotsa gas cuz the o2 sensor isn't sending valid info so it plays it safe, or else it's in it's safe mode.
Old Mar 28, 2005 | 06:49 AM
StreetEG's Avatar
If they did take out a wire...would it be an orange one...cause i was down by the ecu last night and noticed there was a wire clipped.... this cant be good
Eric
Old Mar 28, 2005 | 10:20 AM
red91sit's Avatar
Is it this wire?
A13-MIL MIL (check engine light) Blu/wht
should connect there.
powersk8er92
Sep 15, 2009 11:41 AM
Markb16a
Dec 2, 2006 05:40 PM
spyderracing
18
Oct 13, 2004 11:17 PM
trooper0641
34
Apr 23, 2004 12:29 PM
JBk24crx
Oct 22, 2003 07:57 PM
