obd1 conv
Old Mar 27, 2005 | 08:21 AM
89 pos's Avatar
Default obd1 conv
when doing an obd1 conv and you are using obd1 injectors you dont have to use the inj resitor box right?
Old Mar 27, 2005 | 08:24 AM
abnaasefmb's Avatar
Default Re: obd1 conv (89 pos)
right
Old Mar 27, 2005 | 08:54 AM
Rywire's Avatar
Default Re: obd1 conv (abnaasefmb)
True, you use a plug that runs all the current to the 12v source. Basically this merges the 5 wires that would be at the inj box. You can also solder all of them together.
Ryan
Old Mar 27, 2005 | 05:45 PM
99sonicbluegsr's Avatar
u can still run the resitor box if you use peak/hold injectors right? i may be totally wrong. but i would like to know
Old Mar 27, 2005 | 06:44 PM
eda6's Avatar
Default Re: (99sonicbluegsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99sonicbluegsr &raquo;</TD></TR><TR><TD CLASS="quote">u can still run the resitor box if you use peak/hold injectors right? i may be totally wrong. but i would like to know</TD></TR></TABLE>
Peak/hold injectors require a resistor box.
Old Mar 27, 2005 | 08:02 PM
civickiller's Avatar
Default Re: (eda6)
you can use either type of injectors
Old Mar 27, 2005 | 08:08 PM
Blown90hatcH's Avatar
Saturated injectors(OBD1/2) = remove the resistor box on the EF/ED by soldering all 5 wires together or using a junction plug.
Peak and Hold(PreOBD-OBD0) = run the resistor box. The ecu does not care if you run either injector, but must use the resistor box when required.
Jason
Old Mar 27, 2005 | 08:31 PM
that is what i was thinking thanks for making it clear. i didn't think that it made a difference on which OBD you used, as long as you used resitor box on peak/holds
92 teggy
13
Feb 22, 2010 08:22 PM
makoto
Apr 11, 2007 10:38 AM
crawlin
Aug 17, 2006 06:52 PM
killa rex
Jan 25, 2006 02:54 AM
7rrivera7
Jan 17, 2005 02:07 PM
