Question about rotor wear on integra 10.3" brakes
Old Mar 27, 2005 | 07:42 AM
crexer's Avatar
Default Question about rotor wear on integra 10.3" brakes
Ok i know there are a million posts about DA front integra brakes but my question is different. I used the 90-93 integra knuckles along with gsr calipers on my crx. From what I see the rotor looks as though its not being fully contacted with the brake pads because the inside ring around the rotor is just a complete rust ring on the inside. I just seems as if the pads are only biting around the outside of the rotor. i'll try and get pics tonight if that helps. Anyone else have this problem?
Old Mar 27, 2005 | 05:37 PM
crexer's Avatar
Default Re: Question about rotor wear on integra 10.3" brakes (crexer)
bump it up
Old Mar 27, 2005 | 07:02 PM
HatchBox's Avatar
Skoobie no more...
Maybe the self adjusters are bad on the calipers? And this isnt letting the brake adjust itself?
Were the brake pads new? Did you break them correctly?
Bad pads?
Rotors could be bad?
Old Mar 27, 2005 | 08:10 PM
crexer's Avatar
Default Re: Question about rotor wear on integra 10.3" brakes (HatchBox)
New pads, New autozone rotors, proper brake in (i've done more than 1 brake job), Dunno what it is. Just seems pads arent biting full size of the rotor area.
Old Oct 1, 2005 | 12:28 AM
gkiing's Avatar
TRIAL USER
I have this exact problem on my 87crx with 86 integra front brakes. The left front rotor is worn only on the outside, and has rust on the inside where it should also be worn. My rotors/pads/calipers are new also.
Old Oct 1, 2005 | 07:32 AM
EL Vap133's Avatar
Hmm, I'm slightly confused as to what you are sayng, can you provide a pic?
I have the same front brake set up as you for my 88crx.
Old Oct 1, 2005 | 08:34 AM
crxgator's Avatar
Default Re: Question about rotor wear on integra 10.3" brakes (EL Vap133)
i think he means there is rust around the top hat on the rotor face...
Old Oct 1, 2005 | 08:59 AM
crexer's Avatar
Default Re: Question about rotor wear on integra 10.3" brakes (crxgator)
no not the tophat, i'll get a digi pic in a little while
Old Oct 1, 2005 | 09:30 AM
crxgator's Avatar
so then there is rust around the top near the vents?
usdmftw
Mar 26, 2012 04:02 PM
n8byte
Mar 20, 2007 07:18 PM
seer_claw
Feb 24, 2004 08:13 PM
acuraLSSE95
Jul 28, 2003 06:39 AM
KLN
Feb 21, 2002 04:25 PM
