Tires Rub. Need help!
Old Jan 25, 2002 | 09:41 PM
RacerZook's Avatar
Default Tires Rub. Need help!
Okay. I put 17" rims with 215/40 tires. I started driving it and noticed that the rear tires rubbed slightly in the turns. That fender lip (on the inside of the fender) was barley rubbing the outside edge of the tire. I was told to "roll the fenders" to eliminate the lip, but Ican't find a body shop that will do it (or even knows what it is)and I don't want to attempt to do it myself. I want to lower it with Ebiach sportlines if possible. I just want to stop them from rubbing.
Thanks
Old Jan 26, 2002 | 02:54 AM
vteg's Avatar
New User
Default Re: Tires Rub. Need help! (RacerZook)
If they rub, you will have to roll your fenders to stop it, or get a 205. What is the offset of your rim and rim width?
Old Jan 26, 2002 | 08:22 AM
AlphaKennyWun's Avatar
dont roll the fenders...your paint will crack.
Old Jan 26, 2002 | 09:28 AM
JUNIOR's Avatar
is your car dropped.. if so you may need to rasie it or get the 205 tires
Old Jan 26, 2002 | 09:40 AM
ImprtTunr's Avatar
Default Re: Tires Rub. Need help! (biggest_dookie)
You can cut that lip off if you really need to, I did it on my last car (Civic) so that I could correct the camber a little bit and it worked fine, it looked better than rolling it and havin the paint crack.. You shoulda got 205/40s for your car they wouldnt have rubbed.
b_ron
May 8, 2012 11:09 AM
doggworld1233
42
Mar 29, 2006 01:53 PM
nichols_si
14
Sep 16, 2004 03:28 PM
H.crx-si
Jul 17, 2003 11:37 PM
garados
Feb 3, 2002 12:45 PM
