TIRES RUBBING
TIRES RUBBING
i got 16's 205 45 16
my rear tires rub, before i had 40's an didnt rub at all. I heard on the rear u can use a baseball batt? i tried grinding away at it but not workin really.. any one use a baseball bat trick? details would help thanks boys
HT RULE
HT RULE
oh yea sorry fellas forgot to put more info, they rub right under the quater pannel on the top of the tire. on both sides. just below where the gas cap is the intside part cuts on the tire.. i need to roll the lip. anyone now how difficult? no on hnR springs 1.75 drop
Re: (cxSHOE)
What are your camber and toe settings? Offset and wheel width? Tire Brand?Rolling the lip is easy, but hell on your paint. I scored the paint first so it would crack at the score line (on the fender lip. I then used a pair of vice grips to do the deed, and a metal pipe to clean up. I know of people using ball peen hammers to do the job as well - you can get the lip totally flat against the fender with this technique. Work slowy. Some people heat the paint with a torch to soften it up, but I'm not that brave!
I'm trying to figure out if I can get a set of 215/45/16 Azenis on 16x7s with a 45mm offset under my 99 SI. I run a 2" drop for autocross, and -2 camber. So far the jury is out... any help is appreciated (sorry to thread jack)
the rims are 16x7 no camber kit or anything now i think i need a camber kit on front. but the rear the tire sare rubbing. they are toyo proxies fez4 not cheap to be cutting up. I think i take it to a body shop an get it fixed
Re: TIRES RUBBING (GAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GAccord »</TD></TR><TR><TD CLASS="quote">My 215/45/16's rub in the back with rolled fenders and a 2 finger gap. </TD></TR></TABLE>
you do realize the stock tire size is 175/65-13 rite?
anyways, i ran 205/45-16 on 16x7 slips, +42 offset for a while. on GC coilovers and a 1 finger gap, i rarely rubbed. but with stock springs and struts, it rubbed quite a bit.
Re: TIRES RUBBING (dantastic)
i had 205/45/16 kumhos on 16x7 slips, with ground controls, less than 1 finger gap and never rubbed........ really.
....although the driver side will never ever rub for reasons i will not mention
Munkyw3rkz.webs.com
1 Post
Re: (nichols_si)
you need to roll it then tap it with a light mallet to flatten it out and trim the edge of the bumper that folds in...i had 215x45x16's in the rear of my hatch...looks good adn tucked
Re: TIRES RUBBING (nichols_si)
Right now I'm running 95 GSR's (15 in) with Koni reds cup kit and THAT rubs on the passenger side front. I cut the plastic inside...no help. Still rubs and can't make full U-Turns w/out rubbing. Don't know if it's a suspension issue.
Munkyw3rkz.webs.com
1 Post
Re: TIRES RUBBING (SilVaCiVik)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilVaCiVik »</TD></TR><TR><TD CLASS="quote">Right now I'm running 95 GSR's (15 in) with Koni reds cup kit and THAT rubs on the passenger side front. I cut the plastic inside...no help. Still rubs and can't make full U-Turns w/out rubbing. Don't know if it's a suspension issue.</TD></TR></TABLE>
what size u running? have you folded the tabs from the fender that hold the lining?
