Head gasket cause pinging???
Old Mar 26, 2005 | 11:41 PM
CircuitFG's Avatar
Default Head gasket cause pinging???
Can a head gasket going bad cause pinging???? The motor isn't misfiring or anything yet, but I'm just curious is my slight pinging problem could be caused by a head gasket. . I know it's leaking coolant OUTSIDE the motor, but not sure if it's dropping compression or anything. . what do you think?
Old Mar 27, 2005 | 04:23 AM
mr.beeks's Avatar
Default Re: Head gasket cause pinging??? (CircuitDA9)
what exactly is your defenition of pinging????
headgasket causes
overheating
compresion drop
mixing of oil with coolant
loss of power
Old Mar 27, 2005 | 07:39 AM
CircuitFG's Avatar
a metalic "type" sound that happens between a certain rpm. . . it's happening between about 2-4k rpm when the car is cold. . .when it warms up, it goes away. . .but when the car is cold, there is a slight pinging sound. . .
Old Mar 27, 2005 | 09:20 AM
projectTeG's Avatar
cheack your cam timing and ignition timing.....also did you use a thiner Hg?
Old Mar 27, 2005 | 10:52 AM
CircuitFG's Avatar
cam timing isn't adjusted. . I'm still on the factory gears. .. the timing wasn't advanced at all. .. . and the headgasket is the factory headgasket. . . All i can think of is maybe air/fuel. . .so I'm going to get a fuel pressure regulator/rail/pressure gauge this week and check everythign out. . .
Old Mar 27, 2005 | 11:21 AM
projectTeG's Avatar
you had to take the head off to put a new Hg in, check your timing, i had the same problem my timing was off
Old Mar 27, 2005 | 11:22 AM
CircuitFG's Avatar
i haven't changed my hg yet. . . it's the same one thats been in there when the motor was built. . and the cams markings are all aligned perfectly. . . i think it might be air/fuel. . i HOPE it's air/fuel. . .
Old Mar 27, 2005 | 12:05 PM
projectTeG's Avatar
Default Re: (CircuitDA9)
oh, have you cheacked the crank and seen if its aligned right?
it should be a/f or have you messed with your ecu or f/p?
or it could be your running hotter that you should, also check you plugs wires and cap&rotor goodluck
Modified by projectTeG at 9:39 PM 3/27/2005
Old Mar 27, 2005 | 01:33 PM
CircuitFG's Avatar
Default Re: (projectTeG)
Well, I haven't driven the car in about a week. . I'm gonna be changing everything next week. . (Head Gasket, Intake Manifold Gasket, Fuel Pressure Regulator, Fuel Rail, Fuel Pressure Gauge, Cam Gears, Cam Seals, Valve Cover Gasket, Cap/Rotor, Plugs, and i'll probably change my wires). . . Then i'm goign to get it dyno tuned. . we'll see what happens from there. . . I have a VAFC so they can do more tuning from that. . hopefully it will solve the problem. .
FearDisH22a4
29
Mar 13, 2014 05:10 PM
jdm ek9 101
Sep 12, 2006 07:00 AM
TurdBlown Teg
Dec 7, 2005 11:13 AM
bitchin camaro
Jan 22, 2005 01:29 PM
wessieball
Apr 22, 2002 12:51 PM
