5spd Conversion?
pedal assy, tranny (duh), tranny mount (one is different, passenger side I think it is), lines, clutch slave cyl, clutch.....I forget what else but that's a start.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The G2 Racer »</TD></TR><TR><TD CLASS="quote">pedal assy, tranny (duh), tranny mount (one is different, passenger side I think it is), lines, clutch slave cyl, clutch.....I forget what else but that's a start.</TD></TR></TABLE>
Starter, ecu, shifter, shifter console if you want it to look decent
i did 2 auto to manual and it was easy once i gather all the parts took about 6 hours, but my best suggest dont try it if you have no idea how to do it. also the auto to manual mount for the eg is also nice to have
I do have no idea how to do it, but I have a friend that is doing it for me. i'm just gathering the parts.. lol
lazy ***.. and i'm paying him too
don't forget the linkages. you can run the auto ecu if you don't have a manual one for right now. you will throw codes though but mine ran o.k. for the 2 weeks i had to run it with a auto ecu.
clutch slave cylinder
flywheel
clutch
clutch master cylinder
hydraulic lines
ecu
shiftlinkage
top tranny bracket
front tranny bracket
clutch pedal
brake pedal
flywheel
clutch
hydraulic lines
ecu
shiftlinkage
top tranny bracket
clutch pedal
brake pedal
Going to have to do some custom wiring too, like reverse lights and fooling the car to start in neutral. And being able to take the key out of the ignition, simple procedure if your good at reading and understanding schematic. I would recommend you get familiar with the one for you car.
http://home.comcast.net/~tecgoblin22/000_0097.JPG
http://home.comcast.net/~tecgoblin22/000_0107.JPG
notice in the second pic you can tell it was an auto
Before and after pics
vegaskurt
Apr 14, 2005 10:46 AM
