Help Help!!
91 hatch ls swap, well i got full power an it spins a spins and kicks a few times, but nothing..all over a dam alt., welp i knew it was going up, but no biggie i was gonna let it die then put the new one on..so i was coming home one nite..an the car died like 1/2 mile from my houes"Lucky Me"so i pushed it real fast an jump started it an it acted like total **** on the way home cause i was flooring it, poped a few times an basicly acted like it wanted to cut off..so i got home to my garage an it wanted to die so i was giveing it gas an when i first step on the gas it would studer for a while then clear out..so i turned my head lights off and it ran on its own, for some od reason i took the batt. positive cable off and it died...i was like oh well i'll put a new alt. on it tomorrow an be fine...didn't turn out that way..i put the new alt. on an my injector wiring was alil meesed up so i cleaned it up alil..re soder an tape..an then i tryed to start it nothing so i was like what was wrong, well i wired a injector up backwards an i was like oh shyt..so i fixed that..an tryed to start it still nothing..so then i thought maybe the firing order checked for spark on all cyl. and it is good, both sides of the injectors are hot when i try to start it well one side pulses an then the other is hot on all of them..after checking the wiring harness an checking over all my injector wiring an checking all my fuses an killing my starter an checking the wiring on my Ecu. still nothing, nope all i been doing for the past 2 days is flooding it out an killing brand new plugs an wasting gas, please help im tired of driving the saturn!!
Modified by Ls4thGen at 12:58 AM 3/29/2005
im going to go get some plugs tomorrow...hopfully thats my problem, only thing else i could thing of is the wiring harness, cause my alt, that went bad had like a eletrical smell to it b-4 it went up, but i checked the wires an non of them seemed harmed, and the other thing i could think of was the resitor box, but then again all the injectors are pulsing..well i hope that the only thing it is is the plugs.thanx
welp no luck, car started but it was like a subaru on 2 cyl. an smoked out my garage with black smoke"Way too much fuel", think it could be the dis.? cause its firing an getting fuel, but no start, acts like it wants to start, like when u turn the key it turns over turns over then it kicks a few times but nothing.anyone anywhere, someone this is really racking my nerves,
travishoward
18
Jul 20, 2010 11:10 PM
