Auto Brakes EF!?
Old Mar 26, 2005 | 07:57 PM
SexyAzNMami's Avatar
Default Auto Brakes EF!?
Hi guys, I'm having this WEIRD problem with how my crx drives. I know what's causing it too but can't seem to fix it. When i'm in 1st gear trying to as the car to go with the clutch down.... it seems like the BRAKES is down also. The BRAKES is STIFF and won't even go down but it seems like its on. How did i test this. I drove it up to my driveway, and put it in Neutral and it didn't roll down. It just stayed there. It's like, sometimes when u press the brakes down to HARD, It auto locks itself? What should i check? I jacked up the whole car and had my brother sit in the car while i spinned each of the wheels to see if the brakes where stuck on or not. They spinned fine. This only happends when u presst he BRAKES too hard and it get STIFF.
Old Mar 26, 2005 | 08:22 PM
b16_madman's Avatar
Default Re: Auto Brakes EF!? (SexyAzNMami)
calipers? possibly the pads are thin and the caliper pistons are too far out, getting stuck? highly unlikely, but a thought
Old Mar 26, 2005 | 09:10 PM
xci_ed6's Avatar
Default Re: Auto Brakes EF!? (B16_madman)
slides may be sticking, may need to do a rear drum service (clean, lube & adjust).
Old Mar 27, 2005 | 05:43 AM
Thanks for the help. Check it tomorrow. ^___^
Old Mar 28, 2005 | 09:55 AM
Rywire's Avatar
Looks like the drums are goin out... good luck
Tooooslow
Suspension & Brakes
Apr 5, 2017 12:18 PM
fizzerlee
Jul 14, 2006 10:25 AM
97dc2
May 14, 2006 08:23 PM
integra*RS*
Aug 5, 2002 09:25 AM
