f20 vs h22
Old Mar 26, 2005 | 07:10 PM
HANABLE's Avatar
Default f20 vs h22
pros and cons look to find out all the info i can.
thanks
H.
Old Mar 26, 2005 | 07:18 PM
HANABLE's Avatar
Default Re: f20 vs h22 (HANABLE)
sorry i put this here its also in all motor.
sorry
H
Old Mar 26, 2005 | 07:36 PM
Stew Pidasso's Avatar
Pros: My H22A (in sig)
Cons: I dunno
sorry no help, just a shameless plug
Old Mar 26, 2005 | 09:37 PM
ACC0RD22's Avatar
Default Re: f20 vs h22 (Stew Pidasso)
theyre basically the same engine (pretty much as same as the f22b and h23a) the f20b is just a destroked version of the h22 thats all
Old Mar 26, 2005 | 10:12 PM
Nick H's Avatar
New User
Default Re: f20 vs h22 (ACC0RD22)
only plus of f20b is it's lofty redline (which makes for a much better basis for an all motor setup)...cons include less displacement, or lack of tourque, which is much needed in the world of 4 cylinders...
the pros of the h22 is first of all that they are much more readily available, as are aftermarket parts...therefore, because they are more abundant, the motor is less expensive to begin with...also, the h22 came as an obd1 motor and the f20b did not, which should make it easier to tune...
Old Mar 26, 2005 | 11:35 PM
zensoku's Avatar
f20. High revving vtec at its best.
Old Mar 27, 2005 | 08:24 AM
choclateboi's Avatar
man i want an h22
Old Mar 27, 2005 | 08:34 AM
SuperSlow's Avatar
If you want all the info, look in the lude forum FAQ.
F20b will suck in your heavy accord.
Very interesting spelling for your SN.
Old Mar 27, 2005 | 08:56 AM
TxTuner
Guest
Posts: n/a
Default Re: f20 vs h22 (SuperSlow)
h22 is basically (use the term loosely) the same as the f20
The big difference comes when you have to replace parts. Finding a rod bearing for the h22 will be much easier than for the f20. Just a thought
Old Mar 27, 2005 | 09:21 AM
SuperSlow's Avatar
Default Re: f20 vs h22 (TxTuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TxTuner &raquo;</TD></TR><TR><TD CLASS="quote">h22 is basically (use the term loosely) the same as the f20
The big difference comes when you have to replace parts. Finding a rod bearing for the h22 will be much easier than for the f20. Just a thought </TD></TR></TABLE>
Well just the block has a different bore, different crank, different sleeves, different stroke, different journal width......
That is a VERY loose 'basically the same'.....
They are the same at birth in the refinery and casting, i suppose.
Old Jul 17, 2005 | 06:12 PM
MUGEN_CF4's Avatar
f20b's use p30 rod bearings. ala b16
Old Jul 17, 2005 | 06:44 PM
lowbOOsted's Avatar
I'm a Jackass
F20b revs a whole lot higher and has higher compression but it also cost alot more... -justin-
ThA5oLuTiOn
Jul 17, 2007 01:03 PM
mugenEK
Jul 8, 2004 11:37 PM
PorscheGT2
Sep 20, 2001 10:54 AM
