Write up for replacing Brake MC? (Searched)
Old Mar 26, 2005 | 05:13 PM
monalisa overdrive's Avatar
Default Write up for replacing Brake MC? (Searched)
Looking for a quick write up on replacing the Brake MC for a DC2 (95 ls) and how to bleed the brakes.... Sorry about the newb level help required, i just have always made it a point never to mess with brakes but it's far too expensive not to DIY for this job
Old Mar 26, 2005 | 08:09 PM
integra4991's Avatar
Default Re: Write up for replacing Brake MC? (monalisa overdrive)
IF your going to do work like this you should buy a haynes manual... for 15 bucks its deffnitly worth it when your worken on your car.
Old Mar 26, 2005 | 10:19 PM
SuckMyDOHC's Avatar
its pretty simple... all the bolts you see around the master cylinder needa come off and disconnect the brake lines. then put on the new one, secure it on, and fill it completely with brake fluid. bleeding has to be done in a certain sequence. its as simple as turning a small bolt and pumping the brakes untill the fluid comes out smoothly.
SuckMyDOHC's Avatar
well... at least thats it in a nut shell
hteg12
Jul 18, 2013 05:13 PM
JONESER
Feb 3, 2012 07:28 PM
lxdriver
Dec 17, 2011 10:23 PM
UltimX
21
Feb 8, 2006 08:29 PM
H.crx-si
Jul 6, 2003 10:05 AM
