starter problem
Old Mar 26, 2005 | 04:50 PM
Mleach's Avatar
Default starter problem
I just replaced my transmission, and now that its all back together, I am getting no response from the starter.
What connects to the stud closest to the cross member?
Does anyone have any suggestions? I know this isnt alot to go on, but was wondering if anyone has had a similar experience.
Can I test the starter myself or do I need to pull it off and take it to Advance?
matt
Old Mar 26, 2005 | 04:53 PM
RCautoworks's Avatar
Default Re: starter problem (Mleach)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mleach &raquo;</TD></TR><TR><TD CLASS="quote">I just replaced my transmission, and now that its all back together, I am getting no response from the starter.
matt</TD></TR></TABLE>
The one wire from the main fuse boxs connects to the stud, and there is a clip on the starter that needs to be hooked up.
Old Mar 26, 2005 | 05:11 PM
Mleach's Avatar
Default Re: starter problem (90blackcrx)
Ok, there is the wire from the positive terminal connected to the stud closest to the firewall, then there is the clip that has a wire running from the main harness, then there is the stud that is closest to the bumper. I cant find another wire to attach to it. I went and looked and there isnt another connector from the fuse box. What am I overlooking?
matt
Old Mar 26, 2005 | 07:54 PM
silver hatch's Avatar
check all of yours grounds. i had the same pronlem and fixed it today. mine turned out to be the ecu ground which connects to the thermostat housing. i would say its a ground problem, but if you do a search, then u will find instructions on how to test starter.
magpie.1234
Jul 24, 2015 02:19 PM
T:rex
Apr 20, 2009 09:34 AM
90teg91hatch
Sep 5, 2008 10:07 AM
artraffle
Jul 25, 2005 02:53 PM
91HATCH
Apr 30, 2005 06:23 PM
