beaks sway bar and neuspeed tie bar
Old Mar 26, 2005 | 04:13 PM
Kyles ej1's Avatar
Default beaks sway bar and neuspeed tie bar
i have a neuspeed rear lower tie bar now and want to get a a beaks itr sway bar kit. will the tie bar get in the way cuz i like it and want to keep it?
i tried posting this in suspension but no response, hopefully u guys can help
Modified by 93ejay1 at 5:27 PM 3/31/2005
Old Mar 26, 2005 | 07:43 PM
Kyles ej1's Avatar
Default Re: beaks sway bar and neuspeed tie bar (93ejay1)
ttt
Old Mar 26, 2005 | 08:58 PM
Mashimaro's Avatar
i'm not sure if it'll fit with the beaks, but you could always bolt it up and see i suppose (if the shop will allow it).
i'm running a Skunk2 sway bar and Skunk2 tie bar along with it...but no beaks kit. no problems with fit whatsoever.
Old Mar 26, 2005 | 11:51 PM
Kyles ej1's Avatar
Default Re: beaks sway bar and neuspeed tie bar (Mashimaro)
somebody has to know for sure
Old Mar 27, 2005 | 01:11 AM
Kyles ej1's Avatar
hmmm?
Old Mar 27, 2005 | 10:49 AM
Kyles ej1's Avatar
bump for easter
Old Mar 27, 2005 | 01:56 PM
Kyles ej1's Avatar
omfg wtf!!!!1 nobody knows?
Old Mar 27, 2005 | 02:21 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
The Beaks kit isnt all that great. Ive seen a bunch of people still rip the **** out of the subframe. Go with a reinforcement kit from A-spec or the Comptech setup.
And yea, i do believe you can use the tiebar.
Old Mar 28, 2005 | 10:35 AM
Kyles ej1's Avatar
Default Re: beaks sway bar and neuspeed tie bar (JDM_Ej)
ok i need a for sure answer
Old Mar 28, 2005 | 10:48 AM
ironlung78's Avatar
make model year???
isn't the neuspeed 19mm???
the issue with subframe tearout is 96-00 civic with 22mm bar. you may want to look more into the beaks kit, cause there are a few posts on here where it still tore the subframe, but that was with 22mm TR bar.. you may want to look into subframe reinforcement similar to the comptech or a-spec.
Old Apr 21, 2005 | 04:19 AM
maxogsr's Avatar
Go on the websites of beaksproducts and you'll find out... I know you can fit it but you'll need some other parts... It's all explain on the website!
Old Apr 23, 2005 | 04:00 AM
an2ny888's Avatar
Default Re: beaks sway bar and neuspeed tie bar (maxogsr)
to fit the neuspeed tie bar you have to space it out further from the subframe, get some custom spacers
Kyles ej1
Suspension & Brakes
Mar 27, 2005 12:17 PM
revvin9k
Aug 5, 2004 09:14 AM
Steve_O
Jan 10, 2004 07:58 PM
IntEGNYC
Jan 10, 2003 10:38 AM
Duck Sauce
Dec 8, 2001 12:43 AM
