my bin file for ITR with itbs (Crome and Uberdata)
Old Mar 26, 2005 | 03:09 PM
rice4life's Avatar
Default my bin file for ITR with itbs (Crome and Uberdata)
because of the high number of people requesting to share my bin files, i've decided to post it on here instead of sending it to each individual person. both of these file are tune for WOT on the dyno and street tune for part throttle.
here's the setup: https://honda-tech.com/zerothread?id=1182389
this is Crome bin: http://newvillercspeedway.com/...e.bin
this is Uberdata bin: http://newvillercspeedway.com/...r.bin
here are some pics of the Crome maps
Old Mar 26, 2005 | 07:35 PM
Tbone's Avatar
Default Re: my bin file for ITR with itbs (rice4life)
Nice, you have come along way
I just turned to the dark side today actually!!! I went to radioshack and bought my nokia cable and made my first datalogging cable..
Tbone goes Crome -PRO stay tunned (Thanks to Blundar and John Cui)
Old Mar 26, 2005 | 08:02 PM
chameleon's Avatar
Default Re: my bin file for ITR with itbs (Tbone)
woohoo hurrray Tbone! and bigups to rice4life!
i will be trying this bin very shortly. my only hope right now to get my car movin'
Old Mar 26, 2005 | 08:12 PM
Mike K's Avatar
nice. what's your compression ratio? what cams/header?
Old Mar 26, 2005 | 08:18 PM
RagingAngel's Avatar
Default Re: my bin file for ITR with itbs (Mike K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike K &raquo;</TD></TR><TR><TD CLASS="quote">nice. what's your compression ratio? what cams/header?</TD></TR></TABLE>
Reading ownz jOO Mike!
The setup:
- 98 jdm itr with 4.7 FD and Kaaz LSD
- jdm 4-1 header (ported and reweld)
- carsound 2.5” cat
- megan racing 2.25” cat back
- RM gen2 valve springs and retainers
- obx stage2 cams
- cbr 954 itbs
- walbro fuel pump
- stock 240cc injectors
- aem fpr (set at 50 psi with vac line off)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rice4life &raquo;</TD></TR><TR><TD CLASS="quote">because of the high number of people requesting to share my bin files, i've decided to post it on here instead of sending it to each individual person. both of these file are tune for WOT on the dyno and street tune for part throttle.
Old Mar 27, 2005 | 07:52 AM
rice4life's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tbone &raquo;</TD></TR><TR><TD CLASS="quote">Nice, you have come along way
nice, Crome is an awsome software. as soon as i can find a laptop for cheap, i'll be getting Crome pro. too bad Neptune is not avaliable for purchase.
Old Mar 27, 2005 | 08:15 AM
hybrid_vtec's Avatar
nice, Crome is an awsome software. as soon as i can find a laptop for cheap, i'll be getting Crome pro. too bad Neptune is not avaliable for purchase.</TD></TR></TABLE>
Thats what I am trying to find is a cheap Pentium 2 laptop to use for datalogging and uberdata.
^ Good stuff though. What did you put down at the wheels?
Old Mar 27, 2005 | 09:52 AM
Kendall's Avatar
Props for the .bin, I'll let you know how it does on a B16 very soon.
Old Mar 31, 2005 | 11:59 AM
Jon D's Avatar
Thai....your so generous
Old Mar 31, 2005 | 02:51 PM
Tbone's Avatar
Btw , is this a modified version of my old bin I sent you? It looks alot like one of mine but has more part throttle timming..
Old Mar 31, 2005 | 03:13 PM
Grip's Avatar
Default Re: (Kendall)
thanks for the .bin ill save this for my diy itb setup which i started as of yesterday
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">I'll let you know how it does on a B16 very soon.</TD></TR></TABLE>
please do
Old Mar 31, 2005 | 05:58 PM
rice4life's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tbone &raquo;</TD></TR><TR><TD CLASS="quote">Btw , is this a modified version of my old bin I sent you? It looks alot like one of mine but has more part throttle timming..</TD></TR></TABLE>
no, i start out with a stock p30 bin and added the itbs tool, you can see the last 5 column is TPS base. the bins you sent me were just MAP scalar. i used the bin you sent me awhile back with uberdata. i'm still messing around with the timing on the MAP scalar part of this bin.
Old Mar 31, 2005 | 06:00 PM
rice4life's Avatar
Default Re: my bin file for ITR with itbs (Jon D)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jon D &raquo;</TD></TR><TR><TD CLASS="quote">Thai....your so generous </TD></TR></TABLE>
we're still on for Beaver Spring on April 9th.
Old Mar 31, 2005 | 06:09 PM
JDMlyfestyle's Avatar
hey Thai i tried out the rom and i noticed a dip in the AFR around 3500-4200. so i added a little timing 2 degree's in that range and it ran soo much better..
But i definately give you props on this rom. i just tested the ITB setup but ill be using your rom as a base rom. thanks again for your hard work.
Old Mar 31, 2005 | 08:38 PM
bossman032's Avatar
what is this a cheap version of hondata or something..
is this better then honda data..??
sorry if I sound rude I don't mean to lol
Old Mar 31, 2005 | 11:22 PM
Crome is better than hondata for ITB's since it does have TPS and MAP controls which is the big keys to ITB Tuning.
Old Apr 1, 2005 | 03:52 AM
rice4life's Avatar
Default Re: (JDMlyfestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle &raquo;</TD></TR><TR><TD CLASS="quote">hey Thai i tried out the rom and i noticed a dip in the AFR around 3500-4200. so i added a little timing 2 degree's in that range and it ran soo much better..
But i definately give you props on this rom. i just tested the ITB setup but ill be using your rom as a base rom. thanks again for your hard work.</TD></TR></TABLE>
sounds good, what's your setup? how much did the AFR dip down to at 3500-4200. as you see, there's a dip on the fuel curve at that rpm range on my map. i'll try adding the fuel back in and advance the timing a little and see what happen. that's one of the reason why i posted the bin, to get input from other tuners.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bossman032 &raquo;</TD></TR><TR><TD CLASS="quote">what is this a cheap version of hondata or something..
sorry if I sound rude I don't mean to lol</TD></TR></TABLE>
Crome is a free rom editing software for honda ecu, it works just like uberdata and hondata. you can get the crome pro for $150 which has datalogging and autotune.
Old Apr 1, 2005 | 04:07 AM
Tbone's Avatar
JDM .. post up the new modified bin ..
This will be cool as we all twaek this bin and post our changes....Between all of us it could end up being a really good 'BASE" for people to start with...
Old Apr 1, 2005 | 04:19 AM
DarkSolPR's Avatar
were i can get the Crome software?
Old Apr 1, 2005 | 04:58 AM
rice4life's Avatar
yeah, i would like to hear from every who use this bin and what they modify to make it work for their setup.
Tbone - how did like your ITBs being tuned with Neptune? how was the drivability, idle and cold start.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkSolPR &raquo;</TD></TR><TR><TD CLASS="quote">were i can get the Crome software?</TD></TR></TABLE>
you can find out everything you need to know about Crome here:
http://forum.pgmfi.org/viewfor...320e0
and post all Crome specific questions in the crome forum so all other Crome user can benifit from the feedback.
Old Apr 1, 2005 | 06:41 AM
stevel's Avatar
is there an additional script that needs to be added?
I don't see the TP6 headings and the corresponding percentages. On my version of chrome I see the MAP values. I'm using v 1.0.
Also, is this designed for honda TPS voltages?
Thanks for posting this by the way. I know a lot of work probably went into and it's awesome of you to share that.
s
Old Apr 1, 2005 | 08:00 AM
rice4life's Avatar
Default Re: my bin file for ITR with itbs (stevel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stevel &raquo;</TD></TR><TR><TD CLASS="quote">is there an additional script that needs to be added?
s</TD></TR></TABLE>
you need to get the new version 1.1.2 from the Crome forum. the plug in is already added on the new version. just open the bin and you will see. the tps columns are scaled for honda TPS. there are work being done to allow the use of different TPS other than honda. you can redefine the column headings to anything you want, just double click on the heading and put in new value.
Old Apr 1, 2005 | 08:16 AM
stevel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rice4life &raquo;</TD></TR><TR><TD CLASS="quote">you need to get the new version 1.1.2 from the Crome forum. the plug in is already added on the new version. just open the bin and you will see. the tps columns are scaled for honda TPS. there are work being done to allow the use of different TPS other than honda. you can redefine the column headings to anything you want, just double click on the heading and put in new value. </TD></TR></TABLE>
very nice. thanks so much for the help. dl'd the new version and it looks just like yours. perfect!
s
Old Apr 1, 2005 | 09:49 AM
when i get ahold of my laptop ill post up the bin. i dont have it with me right now. But i modded it better for my setup.
b16a2 stock block
shaved ITR head .040"
ITR cams
AN-R header merge
954 ITB's with stock velocity
Stock injectors in stock location
Fuel pressure 48 PSI
Vtec 5000 RPM's
AFR 14.3 at idle
Cruising AFR 14.4-14.6
Vtec AFR 13.9-14.2
Old Apr 19, 2005 | 04:31 AM
dnoredsi's Avatar
the newest version of CROME is gonna help all the DiY ITB'ers even more now with the option to edit tps voltage to use gixxer or busa tps.
