header questions!
Old Mar 26, 2005 | 01:15 PM
hotdoggies's Avatar
Default header questions!
few questions,i have a 4-2-1 header and was wondering if i could benefit from usins the 4-1 header? they are both dc sports carb legal. Or any other header that would help the cause!
Old Mar 26, 2005 | 01:16 PM
jlacoy82's Avatar
71.192.16.183
Default Re: header questions! (hotdoggies)
4-2-1 will give you better low/midrange, 4-1 will give you better top end. Use a search, billions of topics about this.
Old Mar 26, 2005 | 01:21 PM
hotdoggies's Avatar
Default Re: header questions! (jlacoy82)
Yea mani did the search and it works. I was just wondering if you could trade straight across would it be worth it? 4-2-1 for 4-1
Old Mar 26, 2005 | 02:22 PM
EK9 BEEZLER's Avatar
theres no point if you already purchased the dc 4-2-1 in trying to sell that one and buy a 4-1. the 4-1 might get a you 1-2 hp more than the other but its truly not worth it. and if you are going for some crazy all motor set up or supercharging it then dc isnt the header to have anyway.
Old Mar 26, 2005 | 03:58 PM
JDM H23A's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlacoy82 &raquo;</TD></TR><TR><TD CLASS="quote">4-2-1 will give you better low/midrange, 4-1 will give you better top end. Use a search, billions of topics about this.</TD></TR></TABLE>
I couldn't have said it better
Old Mar 26, 2005 | 07:24 PM
hotdoggies's Avatar
Default Re: header questions! (JDM H23A)
Well i have the 4-2-1 right now the thing iam asking is will my car feel slower with the 4-1 below 4000 rpm?
Old Mar 26, 2005 | 07:30 PM
civictildeath's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotdoggies &raquo;</TD></TR><TR><TD CLASS="quote">Well i have the 4-2-1 right now the thing iam asking is will my car feel slower with the 4-1 below 4000 rpm? </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlacoy82 &raquo;</TD></TR><TR><TD CLASS="quote">4-2-1 will give you better low/midrange, 4-1 will give you better top end.</TD></TR></TABLE>
lo/midrange is o-around 4500 rpm's mid/high is 4000-redline
Old Mar 26, 2005 | 07:36 PM
hotdoggies's Avatar
Default Re: header questions! (civictildeath)
civic till death you have given me alot of info since i have been here thanx man! You think i should go with the 4-1 instead?
Old Mar 26, 2005 | 07:48 PM
it depends on how you drive your car.
me= always above 4000 rpm's so if i get a header it will be a 4-1 simply because a 4-2-1 will slow my roll.
if you drive at lower rpm's id stay with the 4-2-1
but if you plan to go turbo, i would keep what you got
its all in the foot of the driver
Old Mar 26, 2005 | 07:54 PM
hotdoggies's Avatar
thanx man one final question. will the 4-1 off a 99 b-16a fit on a 2000 b16a2?
Old Mar 26, 2005 | 08:01 PM
yes, b series are interchangeable with each other
Old Mar 26, 2005 | 08:04 PM
hotdoggies's Avatar
Did the b-16a2 make more power than the b16a?
Old Mar 26, 2005 | 08:07 PM
http://tech.hybridgarage.com/tech/specs.htm
Old Mar 26, 2005 | 08:35 PM
hotdoggies's Avatar
What is the best way to get keep header bolts from stripping?
Old Mar 26, 2005 | 08:50 PM
Mashimaro's Avatar
anti-seize compound on the threads before you install the header. then torque them down with a torque wrench to 23lbs (i think that's factory spec.). becareful not to over tighten cuz if you break a stud, you're screwed. good luck bro!
Old Mar 26, 2005 | 10:43 PM
hotdoggies's Avatar
Default Re: header questions! (Mashimaro)
bump
Uncle Ben's
Nov 21, 2007 06:08 AM
RussHondaCRXVtec
21
Sep 25, 2003 10:25 AM
Dustin98Integra
Jan 25, 2002 10:11 AM
DaNish
Oct 9, 2001 06:47 PM
