NOOB HERE TO SWAPS NEED INFO ON B18B SWAP IN 93 CIVIC EX WAS TURBO
HEY I LOOKED IN THE FAQ SECTION DIDN'T FIND NOTHING FOR B18B SWAP I NO ITS A STRAIGHT BOLT IN FROM WHAT I WAS TOLD BUT WHAT WILL INEED TO COMPLETE IT AS FAR AS WIRING I ALREADY GOT THE SWAP I JUST NEED IT PUT IN IS THERE ANY THING I SHOULD NO ? I GOT A COMPLETE SWAP FOR 1000 COULDN'T LET IT GO FOR THAT . WELL ANY IN FO WOULD BE GREAT THANKS
First, take off caps lock. Then search. To put you in the right direction however: axles, mounts, tranny, harness, ecu, and some patience. But really, it has been covered a number of times.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jeef84 »</TD></TR><TR><TD CLASS="quote">First, take off caps lock. Then search. To put you in the right direction however: axles, mounts, tranny, harness, ecu, and some patience. But really, it has been covered a number of times.</TD></TR></TABLE>
That didnt even come close to answering his question. Nor did it "point him in the right direction".
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dsmarefaster »</TD></TR><TR><TD CLASS="quote"> I NO ITS A STRAIGHT BOLT IN FROM WHAT I WAS TOLD BUT WHAT WILL INEED TO COMPLETE IT AS FAR AS WIRING</TD></TR></TABLE>
Well ,the b18b swap is obd2 and your civic is obd1.
If you have the complete b18b swap(including the engine harness) then all you need to do is drop it in, plug the b18b wiring harness into your civics harness(the obd2 engine harness will plug straight into your obd1 civic harness), then plug in an obd1(b18a) LS ecu. Thats it.
No wiring changes at all.
What the hell are you talking about? You mean to tell me a 94 teg ls doesn't come with a b18b1 motor? Because I'm willing to bet it does. For one, he didn't even mention what year the teg he was getting the b18 was, and just because it's a b18b doesn't mean it's obd2. The b18b is the upgraded form of the b18a that was found older model tegs. You need to do your research and stop trying to sound so uprighteous.
i thought the moderators at HT deleted any posts with "all caps."<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jeef84 »</TD></TR><TR><TD CLASS="quote">What the hell are you talking about? You mean to tell me a 94 teg ls doesn't come with a b18b1 motor? Because I'm willing to bet it does. For one, he didn't even mention what year the teg he was getting the b18 was, and just because it's a b18b doesn't mean it's obd2. The b18b is the upgraded form of the b18a that was found older model tegs. You need to do your research and stop trying to sound so uprighteous. </TD></TR></TABLE> hes right
Yeah dipstick, im gonna have to agree with this guy here.
tannerLSt
Texas -OK -LA (Sales)
Apr 26, 2006 01:26 PM
