Simple Question....What is.....
What is the coolant valve next to the rear L bracket for?
Does it have to be positioned perfect? Cause I broke the mounting bolt for it and don't know if I should just put it back on.
Thats the cabin heater temp control valvle ( I guess from your description). It controls coolant going to the heater core. If its not affixed to the firewall you might malfunction the temperature slider. I had to remove mines when I put in motor mount inserts.
AMBiEN22
Jun 24, 2011 09:44 AM
sanegb16
Sep 5, 2007 01:41 PM
