Why not just a S-AFC?
I'm fairly new to honda's, but I have jumped in head first. I come from the nissan family, so please bear with the dumb questions.
I bought an intega gsr, and have torn the b18c1 down due to the low compression pistons that were in it. I am in the process of rebuilding it with USDM ITR pistons. Everything else on the motor will remain stock, except for the eagle rods. It has a stock gsr head. The computer that came with the car is a JDM P73. I am planning on running a stock head gasket. BTW - this is a race only car (road racing). It will never see the streets.
I keep seeing everyone reccomend a P28 chipped, but my question is why? Why would I run some program that someone created in their basement? Why wouldn't I just buy a S-AFC and go to get the car tuned with it? Am I missing something here? I dont want to go with uberdata, or hondata just yet, as I am in the beginning stages of the learning curve, and just need a car to race right now. Should I stick with the P73?
well as far as the s-afc you could use it but you can get more out of a v-afc since it will also control the vtec and when it will engage while it still gives you the fuel control.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rEGan »</TD></TR><TR><TD CLASS="quote">Correct me if I'm wrong!
Have you used the compression cal. The USDM ITR pistons wont up the compression that much...
Maybe your going for reliability.
I'm road racing in a class that only allows so much compression. Believe me, if I could get the compression up to 11:1 or 11.5:1, I would be all over it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatch’d »</TD></TR><TR><TD CLASS="quote">well as far as the s-afc you could use it but you can get more out of a v-afc since it will also control the vtec and when it will engage while it still gives you the fuel control.</TD></TR></TABLE>
Excellent, that is probably what I will use.
Back to the original question, is the P73 one of my best (and easiest) options? Or should I go for another ECU. I'm guessing I should stick with the P73 for ease and reliability.
for what a apexi v-afc or s-afc costs u can get a chiped ecu and use hondata,crome,ghettodyne etc to do tuning....much better way to spend your money....plus you have way more controll over the engine...and u can setup full throttle launch and full throttle shift....something v-afc or s-afc cant do....u can also adjust timing maps with chiped ecu.....chiped ecu
iceman95
Mar 2, 2006 09:24 PM
