B-series Trannys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g2integra217 »</TD></TR><TR><TD CLASS="quote">Im wondering what tranny codes are what like
YS1
S1
A1
Y1
J1 how you know if it has LSD or what have you... </TD></TR></TABLE>
those are all cable b series trannies
a1= 90-91 ls trannie small spline
s1 and j1= jdm b16 short geared cable b16 trannies 4.4 final drive graeing like the usdm itr and hydry b16's also is small spline used 90-91 clutch
y1 = no good. jdm long geared b16 trannie. came off jdm b16 crx. also is small spline. 4.2 final drive graeing is slightly longer and bigger than hydro gsr trannies and way longer than regular b16 trannies but still much shorted that ls trannies.
ys1 = any 92-93 hydro trannie. you cant tell if its a ls trannie/ b17 gsr trannie or jdm b16 trannie. this used the big spline clutch 92-01 clutch.
all of the above trannies has optional lsd from japan except for the a1 cuz its a ls trannie
YS1
S1
A1
Y1
So A1 is the longest geared tranny? and S1 is the shortest? Also Ys1 isnt hydro its still cable just used hydro big spline clutch. Also a Y1 isnt ok for a Vtec motor?
<A HREF="http://www.ff-squad.com/tech/temp/Bgears.htm
" TARGET="_blank">http://www.ff-squad.com/tech/temp/Bgears.htm
</A>
</A>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g2integra217 »</TD></TR><TR><TD CLASS="quote">So A1 is the longest geared tranny? and S1 is the shortest? Also Ys1 isnt hydro its still cable just used hydro big spline clutch. Also a Y1 isnt ok for a Vtec motor?</TD></TR></TABLE>
s1 came in USDM 90-91 tegs(long gear) AND jdm b16 engines(shortgear)>
y1 is jdm b16 and itll be fine on vtec engines>
it isnt as short as jdm s1/ or ys1 gsr/jdm b16 ones tho
BTW, LSD trannies have LSD printed on them, but that writing quickly comes off. look through the differential. if you can see through it, it's a limited slip unit. if you can't see through it, it's an open diff.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95lstegman »</TD></TR><TR><TD CLASS="quote">BTW, LSD trannies have LSD printed on them, but that writing quickly comes off. look through the differential. if you can see through it, it's a limited slip unit. if you can't see through it, it's an open diff.</TD></TR></TABLE>
if you can see all the way through with nothing in the way its LSD., and if you see through and theres a bar in the dif. its open
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importdude2000 »</TD></TR><TR><TD CLASS="quote">
it isnt as short as jdm s1/ or ys1 gsr/jdm b16 ones tho</TD></TR></TABLE>
do not get a y1 b16 trannie
i have one and the gears are not close to as short as the s1/j1/ itr trannies
the gears are even longer than hydro gsr trannies
it falls between a hydro gsr and a ls trannie
example
itr / b16 trannie 80 mph 5th gear = 4.2k
hydro gsr 80 mph =4k
ls = 3.5k
y1 trannie = 3.8k
example
ls = 3.5k
y1 trannie = 3.8k
xsuperxsonx
Jan 11, 2006 08:41 PM
