LS vs. B20VTEC swap
Old Mar 25, 2005 | 09:22 PM
Ferio Whores's Avatar
Default LS vs. B20VTEC swap
I'm about getting a swap. Can you guy help me to decide ? LS or B20VTEC, I did lot of research. Just wanna see your opinion. Thanks a lotz guy
BTW: this swap is gonna be on the EG9
Old Mar 25, 2005 | 09:47 PM
oldskooljdm's Avatar
Default Re: LS vs. B20VTEC swap (Ferio ******)
dont really see what the difficulty is in deciding on your swap??
LS would be good if you are thinking about boosting in the future but other wise if you wanna stay all motor then go B20VTEC
Old Mar 26, 2005 | 06:42 AM
thanks dude
Old Mar 26, 2005 | 08:15 AM
13HYBRID20's Avatar
You did a lot of research but you don't know what to pick?
Old Mar 26, 2005 | 08:31 AM
Spoon 722's Avatar
Default Re: (13HYBRID20)
I've seen some mad horsepower numbers out of B20Vtec's those motors have a bit of torque and they accept boost very easily. But Idk I would go with a B20Vtec because everybody has a LSvtec
Old Mar 26, 2005 | 08:48 PM
cool, thanks
Old Mar 26, 2005 | 08:52 PM
Good ol' Screwtape's Avatar
Multi-paradigm
Default Re: (Spoon 722)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoon 722 &raquo;</TD></TR><TR><TD CLASS="quote">I've seen some mad horsepower numbers out of B20Vtec's those motors have a bit of torque and they accept boost very easily.</TD></TR></TABLE>
they accept boost easily? i thought b20 blocks had thin sleeves?
on me if i'm misinformed.
anyway, what's the swap for? racing or daily driving? and when you say LS, do you mean stock LS or LSVTEC? if you don't race, and it's just for daily driving, i would go stock LS hands down because it'd be cheaper, cleaner, less work, and would give you a decent amount of daily driving power improvement.
(if you meant LSVTEC, then forget everything i just said.)
Old Mar 26, 2005 | 09:20 PM
The G2 Racer's Avatar
Default Re: (Screwtape:)
If you just want to toss an engine in, I'd go with the B18B, cheaper.
Personally if I was going the B20VTEC route, I'd want to build it up nicely (for boost or n/a), sleeve the block, etc.
All depends on what you want to spend.
Old Mar 26, 2005 | 09:41 PM
takendaily's Avatar
my friends got a b20vtec n/a setup. pulls pretty good. not really much done to it, but i've seen a dyno chart that shows almost 300hp out of an n/a b20vtec
Old Mar 27, 2005 | 07:45 AM
gReeN gOblIn 11's Avatar
id go ls turbo if i were you b/c of cost...if your down for building up the motor and have deep pockets b20vetc pulls hard man....but there also is nothing like a turbo spooling up and blowing off
Old Mar 28, 2005 | 09:20 AM
Spoon 722's Avatar
Default Re: (DannyVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Screwtape: &raquo;</TD></TR><TR><TD CLASS="quote">
on me if i'm misinformed.</TD></TR></TABLE>
I was under the impression he was going to build the block, which
A main part would be resleaving he didn't explain what
exactly his plans are so I'm not going to argue over something we
guessing blind on.
Old Mar 28, 2005 | 12:59 PM
clint g's Avatar
Me personally i would go lsvtec because the cylinder walls are very thin and the b20 wasn't meant to rev past 6 grand the ls you have the same stroke just an 81mm bore so you can slap some type r slugs in their for an extra kick. That is my opinion cause im bought to buy an ls for my 4 door I am just going ahead and making plans
Old Mar 28, 2005 | 01:05 PM
dohcdelsol93's Avatar
Default Re: (clint g)
i chose ls because it was readily avaliable and had plenty of used parts. I have the ls in my sol now and a ls/vtec in the final stages
Old Mar 28, 2005 | 01:52 PM
BLANKS143's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clint g &raquo;</TD></TR><TR><TD CLASS="quote">Me personally i would go lsvtec because the cylinder walls are very thin and the b20 wasn't meant to rev past 6 grand the ls you have the same stroke just an 81mm bore so you can slap some type r slugs in their for an extra kick. That is my opinion cause im bought to buy an ls for my 4 door I am just going ahead and making plans</TD></TR></TABLE>
the b20 has the same redline as the b18b and its 7k. i know this cause i have a stock b20 w/ sc50 in my car. also if you tune the b20 right, you wont have any problems boosting under 10psi, over 10+psi you can prolly get away with a couple times but not for daily driving. i boost 8psi and 10-12psi at the track. also you have to realize its not boost that cracks sleeves, its the amount of hp its putting out.
like everyone says, if you plan to stay na, i would go with the b20/vtec, if you plan to boost on a stock engine, then b18b.
Old Mar 28, 2005 | 02:18 PM
Contraband's Avatar
apples and oranges man. is it really that hard of a choice??? You must research like a third grader.
Old Mar 28, 2005 | 05:26 PM
ProJectCvic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 13HYBRID20 &raquo;</TD></TR><TR><TD CLASS="quote">You did a lot of research but you don't know what to pick?</TD></TR></TABLE>
If you did your research, then you would find that there are people in your shoes also..read their posts.
Old Mar 28, 2005 | 05:30 PM
^CX_d16's Avatar
Default Re: (ProJectCvic)
i have LSvtec in my 4 door
Old Mar 29, 2005 | 09:35 PM
thanks alot guyz
Old Mar 29, 2005 | 10:01 PM
Daves_b18r's Avatar
b20 vtec more power
noodlez1390
Jul 3, 2008 12:43 PM
Huntley2147
55
Jun 23, 2007 01:30 PM
slow_redcivic
Oct 7, 2005 01:04 PM
Veil_Side_
Jan 26, 2002 06:55 PM
vtecsiqt
Jan 20, 2002 10:10 PM
