b16 swap into EK..no fuel pump..
i swapped my b16 into my Ek...
i hvae no fuel pressure..it doesn't turn on..j/w if anythin needed ot be changed for it to work wtih a b16 from obd1....proobly not...this is a waste of a post...
later..
what could be wrong
pump is not there...cause i bought this car rolling chassis style
pump is shot..
pump is gettin no juice b/c jackass did weird wiring...
i suck at honda's
hit me up...later
later..
what could be wrong
pump is shot..
i suck at honda's
hit me up...later
What ECU are you using? If you're using a different OBD-2 ECU that is not a 96-model ECU, then it's the immobilizer. The immobilizer cuts off power to the fuel pump. If you're using an OBD-2 to 1 ECU adapter harness, then make sure that thing is wired up correctly so that it's giving power to the fuel pump.
bluecrxsi
Jun 5, 2003 06:35 PM
