195/50/15
You hit a pot-hole w/ 195/50/15, it'll do some nice damge to your rims than if you were running 205/50 or 195/55.
FYI - don't run Azenis during Seattle's rainy months. You'll hydroplane.
Nah those are both not true. I hit potholes all the time. No rim damage. The difference between the 95/55 and /50 is pretty negligable.
I ran 195/50s for about 10K miles with no problems. The speedo was off at higher speeds, but no big deal. Not much tread on the ground though, compared to the 205/50s I have now.
shorter revs. i have 195/50-15s with no bends due to pot holes and after shifting at 8K i now land at 6K instead of 5.7K. first gear anyway. B16a w/Y1 tranny.
The change from 195/55-15 to 195/50-15 will make the speedo (and odo) read roughly 3.3 percent higher at all speeds.
*edit* you only notice the speedo off at higher speeds
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
Wrong. Changing the size of your tires doesn't change the revs that you land at. That's determined only by the difference between the ratios of the two gears.
you will save some weight. You will also reduce the overall diameter of your wheel, increasing your gear ration so the car should accelerate faster, but I don't know if you will notice it. You will also throw your speedmeter off by 2-3 mph/
wizzards581
11
Mar 22, 2004 12:38 AM
