Reason tach isn't working?
Old Mar 25, 2005 | 05:05 PM
99R-type's Avatar
Default ANy reasons why my type r cluster tach isn't working....
I need help...
When i turn on my engine, my tach inside the cluster doesn't work, But the temperature gauge and fuel gauge works. Why is this? anybody have any clue?
Any help would be appreciated. Thanks in advance
Old Mar 26, 2005 | 07:34 PM
Cosworth's Avatar
Default Re: ANy reasons why my type r cluster tach isn't working.... (99R-type)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99R-type &raquo;</TD></TR><TR><TD CLASS="quote">I need help...
Any help would be appreciated. Thanks in advance</TD></TR></TABLE>
What car do you have? A '99 Canadien spec ITR? Or, what?? We need more info to help you out.
Old Mar 27, 2005 | 09:08 AM
Blind-Fashion's Avatar
Old Mar 27, 2005 | 11:12 AM
99R-type's Avatar
Default Re: ANy reasons why my type r cluster tach isn't working.... (Cosworth)
I have a usdm spec 99 integra gs-r with type r cluster and full swap. any help is great
Old Mar 27, 2005 | 12:22 PM
CleanShaven's Avatar
it could be your wiring or that the cluster is fucked up.
Old Mar 27, 2005 | 01:47 PM
nightrider's Avatar
i was going to advise you to take your car in for warranty if your car was still applicable, but since that's not the case, use your gsr cluster or a loaner cluster from a buddy to see if your itr tach is the cause of the problems. figure that part out and then move from there. gL
Old Apr 3, 2005 | 05:06 PM
1 point 6's Avatar
Down Since Day 1
Community Builder
Community Influencer
Default Re: ANy reasons why my type r cluster tach isn't working.... (nightrider)
i have the same problem, im going to check the continuity in the wire in the main harness right behind the firewall.
j3dimindtr1cks
Honda Civic (2001 - 2005)
Sep 21, 2006 08:18 AM
jdm2teg
Feb 21, 2006 08:38 PM
vmm
Apr 18, 2005 04:05 PM
chinkyEyez
11
May 21, 2004 01:51 PM
