well i just failed emissions again -_-
Old Mar 25, 2005 | 04:13 PM
egcivic's Avatar
Default well i just failed emissions again -_-
okay, well i failed the first time i figured.. bad cat?
so i replaced it, and then went back for round 2.
where i failed once again, with two cats... >.<
now i am stumped, i have three months so no hurry.. but
i jus wanted to ask you guys what the problem might be before i go out and buy a new engine
edit --- o yea, i failed with almost double the standards both times
Old Mar 25, 2005 | 04:19 PM
Nic's Avatar
Nic
do a tune up cap rotor wires plugs a fuel injection cleaning the 3 stage and replace your o2 sensors.
Old Mar 25, 2005 | 04:43 PM
egcivic's Avatar
Default Re: (Nic)
i was thinking of doing a tune up.. but then it would cost about as much as i could get a used d16 for, which i know might not pass emmisions( hopefully i buy one that will ) but id feel realli bad dropping all that cash into a d15b8 thx tho i kno what parts to replace when i do do a tune up!
if it helps.. i put a 96 + header on there with the cat built into it after my first fail.
before i put that on the o2 sensor was black..
after it was white...
i kno for spark plugs that means either lean or rich.
would it be the same for the o2 sensor?
Old Mar 25, 2005 | 04:47 PM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
Default Re: (egcivic)
what part did u fail? Teh visual, emmisions, or CEL test? If u failed emmisions, post up the results from the test
Old Mar 25, 2005 | 05:29 PM
Falqon's Avatar
change the oil, retard the timing around 3-4 degree's from stock.
Old Mar 25, 2005 | 06:15 PM
SGVridgerunner's Avatar
Default Re: well i just failed emissions again -_- (egcivic)
Agreed, retard the timing a bit. Do you have headers? How far off were you from passing?
Old Mar 25, 2005 | 11:20 PM
egcivic's Avatar
Default Re: well i just failed emissions again -_- (SGVridgerunner)
i failed the emmisions part, and it doubled the output of everything that was measured.
id put the charts up but i dun have a scanner here.
i can when i get back to school in a few days.
when i tested it i had a 96 + stock header on it, so i was running two cats
Old Mar 25, 2005 | 11:30 PM
95dxhatch's Avatar
so you were more then double the standards for both HCs and COs? different areas test for different things. if you were over on both HCs and COs its a rich misfire. if you could post numbers up at idle, 1500 and 2500 or whatever they test at that would help a lot.
also, did you change the oil right before you went? what kind of gas were you using? and did u drive the car some before testing and NOT shut the car off while waiting in line?
Magick211
Oct 28, 2006 02:51 PM
Edulerp
Jul 15, 2006 02:48 PM
crx-treme
Aug 4, 2005 10:58 AM
WTB AUTO EK
Apr 9, 2005 11:24 PM
Splangtastic
Jun 19, 2003 01:30 PM
